Macro to send email after changing from address and adding signature
Outlook 2013 64 bit
When composing and email and we're ready to send, we need a macro that will change the from email address, then add a signature and then send the email.
Any help would be very much appreciated.
Michael Bauer
See the SendUsingAccount property for setting the account, or see SentOnBehalfOfName for setting an address (this works only with an Exchange account).
Good luck for the signature, since OL 2013 there's no easy way. Best approach could be to save a template for each account/signature, and send copies of that.
H send reminder if no reply received on first or original email using macro Using Outlook 2
K Macro Not Executing then send email from Explorer Outlook VBA and Custom Forms 3
T Using a macro to send email to diffrent address Outlook VBA and Custom Forms 1
M Use a macro to send files by email Outlook VBA and Custom Forms 3
E macro to send an email when an EMAIL reminder fires Using Outlook 1
O using macro to send attachments Using Outlook 3
B Looking for Outlook 2013 update for Send Drafts Macro Using Outlook 4
Q Outlook Macro to do a send/receive on specific group Outlook VBA and Custom Forms 1
L Modifying VBA script to delay running macro Outlook VBA and Custom Forms 2
S Macro to extract and modify links from emails Outlook VBA and Custom Forms 1
L Macro to add Date & Time etc to "drag to save" e-mails Outlook VBA and Custom Forms 2
