Emails do not appear in Sent box!
DanHunter
Good Afternoon and thanks for reading my issue,
I am sending emails from my personal IMAP account on my phone. These are not appearing in my outlook 2010 sent box on my PC. I believe this used to work in the past. I imagine it is something really easy, so I apologize in advance.
I have an android phone and use the outlook mail app.
Any help would be great appreciated,
Many Thanks,
Dan Hunter.
What folder is the app using for sent items? Are the missing messages in another folder in Outlook?
The usual cause is that the device is using a different folder for sent items - you might have two sets of sent, deleted and junk folders. If the account is gmail, look under the [gmail] folder in outlook.
DanHunter
Good Morning Diane and thanks for the reply.
The sent items do in fact go to another sent folder called NAME SENT shall I just set it to the normal folder?
Unfortunately it is not a gmail account.
If the app allows you to choose a different sent folder, do so. You can't change it in Outlook.
DanHunter
Many Thanks Diane,
That has solved the issue completely.
Dan.
R Outlook 2010 Sent emails don't appear in the sent mail folder Using Outlook 9
J Some Emails I send do not appear in my 'sent' file. Using Outlook 1
T Render Outlook emails in MS access as they appear in Outlook Outlook VBA and Custom Forms 2
P Outlook 2013 Mail Notifications appear for ALL emails--no good Using Outlook 1
M Emails Appear Blank in Outlook 2007 Using Outlook 1
G In Outlook 2010, how do you get an envelope to appear in the system tray when new emails arrive? Using Outlook 2
J setting up outlook - cannot get my email account recognized-test emails appear in older outlook on a Using Outlook 2
E Inbox emails appear for a brief instant and then Inbox shows no content Using Outlook 2
C Emails appear empty but I know they are not Using Outlook 1
T Deleted emails do not appear in Delete folder. Using Outlook 1
M Missing/Blank Hotmail Emails from Outlook but appear in hotmail BCM (Business Contact Manager) 1
J Outlook 07 emails all appear READ now my Blackberry activ. Want UN BCM (Business Contact Manager) 1
P Outlook for Mac - emails are not sent out beginning last week Using Outlook 1
N Extract Outlook emails to excel Outlook VBA and Custom Forms 2
M Group of emails Using Outlook 1
D Assign categories to outgoing emails Outlook VBA and Custom Forms 0
P Flagging emails in conversations Using Outlook 2
D Outlook 2016 Deleting emails without affecting folder structure - Outlook Office 365 Using Outlook 3
M Filter Conversations - Filter Out Single Emails Outlook VBA and Custom Forms 3
F not receiving emails until i re-login Using Outlook 2
A Record opened emails for reopening later Outlook VBA and Custom Forms 16
R Deleting emails from storage folder Outlook VBA and Custom Forms 1
S How can I delete all copies of a given companies logo graphic from all my emails at once? Using Outlook 3
L Time format in Outlook calendar and emails Using Outlook 0
G Parsing All Emails Outlook VBA and Custom Forms 8
J Set Timer/Countdown on Emails? Outlook VBA and Custom Forms 3
O Delete duplicate emails - subscription notifications Using Outlook 5
