See recent emails from a sender
ONUK
Outlook 2016 64 bit
In Outlook 2013, when reading an email, there was a small upwards pointing arrow. Click on the arrow and it showed you a list of recent emails from that sender. It was a quick and easy way to find related mail.
In Outlook 2016 ...... I can't find it - I've searched every menu, inside out - and I desperately want it back.
I'm abroad in a remote location, so can't roll back to 2013 until I get home.
Any help would be gratefully received!!!!
I've posted in MS Communities but have had no replies, so here's hoping ......
That was the people pane. Look for people pane button on the View ribbon - should be on the right, next to folder pane, reading pane, and to-do bar buttons. if not there, look in file, options, addins for social connector. Is it enabled?
ONUK
Outlook 2016 64 bit
Diane - you're a genius - exactly what I needed. Thank you so much :D
M Recent emails disappearing Using Outlook 4
V Pin a document to the "Attach file" Recent Documents list Using Outlook 0
A Order of Recent Items in Attach File List Using Outlook 5
makinmyway Recent Files Not Updating when Using Insert Hyperlink in Outlook 2013 Using Outlook 0
C connecting to recent outlook file on new hard drive Using Outlook 2
D Outlook 2010: Conversations view - most recent activity posts to of inbox? Using Outlook 2
B Having Recent Issues with Hotmail Connector? Using Outlook.com accounts in Outlook 17
T OWA 2007 recent recipients and OWA 2010 nicknames Exchange Server Administration 5
J Sent Items Folder Isn't Showing the Most Recent Sent Items Using Outlook 7
A Record opened emails for reopening later Using Outlook 2
T Outlook creating unwanted tasks in Tasks and Todo from emails Using Outlook 1
Horsepower Moving emails between folder Outlook for Mac Outlook Wishlist 8
B Outlook 2016 Outlook crashes when trying to print certain emails Using Outlook 5
L IMAP Emails Disappear Using Outlook 0
D Duplicate Emails on Phone and Tablet Using Outlook 0
C Multiple emails Using Outlook 3
Phillip Bit.ly emails Using Outlook 1
G Alerting on missed emails in conversation Outlook VBA and Custom Forms 1
P Outlook for Mac - emails are not sent out beginning last week Using Outlook 1
N Extract Outlook emails to excel Outlook VBA and Custom Forms 2
M Group of emails Using Outlook 1
D Assign categories to outgoing emails Outlook VBA and Custom Forms 0
P Flagging emails in conversations Using Outlook 2
