Outlook 2013 how to convert 2013 OST file into an another format, i m using outlook 2013 versions.
jessica tores
Outlook 2013 64 bit
i m using Outlook 2013 outlook version and it has a file of extension .ost , so i want to convert my OST file into PST format , and i also don't know its located path, so suggest me a best way to convert my OST data into PST format.
The default location for ost files is %localappdata&\microsoft\outlook. Moving them is difficult so most people don't - it's highly likely that is where the ost is - if it still exists. You need to export to a pst before removing the account from outlook 2013 or 2016. When you remove the account (either imap or exchange), the ost is deleted by outlook.
Is this an IMAP ost file? If so, AFAIK, none of the commercial products will work with it.
If it's an Exchange ost, any one of the products on this page will do it - Convert an Offline File (.ost) to a Personal File (.pst) - note that there are apparently a lot of these programs available but many are just knock offs (licensed for rebranding) of the top brands.
M Convert Subject Line to Internet Header version of Subject Outlook VBA and Custom Forms 10
P How do I convert outlook “to-do” items to “tasks” Outlook VBA and Custom Forms 1
C convert an .ost to .pst Using Outlook 3
D The way to convert ost to pst Using Outlook 2
sneaky30 convert text to date Outlook VBA and Custom Forms 1
Diane Poremsky Convert an Offline File (.ost) to a Personal File (.pst) New Slipstick.com Articles 0
S How to do I convert OST file to PST? Exchange Server Administration 3
J convert .pst to .eml, how is it possible? Using Outlook 1
M convert/import a customized record into the default "Account" record BCM (Business Contact Manager) 0
V Check/convert to emailaddresses Outlook VBA and Custom Forms 11
R Convert Access table to pst Using Outlook 1
L Convert Distribution List of Contacts to Single Contacts Using Outlook 6
G Is there any way to convert outlook 2003 to outlook 2007 Using Outlook 5
D Outlook contacts no in address book - 2002 pst file convert to 2007 pst file? Using Outlook 0
A Outlook 2003: convert all RTF emails to HTML Outlook VBA and Custom Forms 1
J How to convert BCM contacts to normal Outlook contacts BUT... BCM (Business Contact Manager) 2
G Tasks - convert email to task & attach email Outlook VBA and Custom Forms 6
A Re: Convert Oportunity to Project? BCM (Business Contact Manager) 3
B convert VBA code to Add-in Outlook VBA and Custom Forms 1
Q How tough is it to convert VBA to Addin Outlook VBA and Custom Forms 1
T Office 2013 no longer updating automatically Using Outlook 2
