Trouble with Office 365/2016
Gary Berg
Outlook 2013 32 bit
My wife's computer is having trouble with Outlook 2016 crashing. I've seen error 0xe0000001. This appears to be an "unknown error" error. This will happen with Outlook just sitting there, or you can be typing away and get it.
I also find that her PST file gets corrupted and needs to be fixed with Scanpst. Yes, I run Scanpst multiple times. I have her set up with two pst files to keep her default pst smaller. That default pst file is on old Outlook 97-2003 format, the second one is the newer format.
I see two paths here; convert the old format file to the new format, or do that plus uninstall Office, run an MS clean tool, and reinstall. Obviously I'd prefer to not reinstall Office if it not necessary. I don't think that any of the other Office programs have problems.
The machine runs Windows 7.
Any suggestions?
Sorry i missed this earlier - i guess spammers are good for something after all. :)
I don't think reinstall will help - the new versions of outlook doesn't work well with the old pst format, especially as the default or a delivery location. It would be best to import that old one into a new pst.
How big are the two pst files? You shouldn't have problems using just 1 pst if it's under 10GB, definitely not if it's under 5 GB. Over 10 GB should be fine too, but outlook might seem slower.
Gary Berg
Outlook 2013 32 bit
I finally gave up and imported the old format pst into the a format one. That seems to have resolved the problem. I didn't combine the two pst files.
B Trouble Locating Tools Menu since There's No Standard Toolbar in Office 2010 Using Outlook 1
M Trouble downloading Outlook on an Android phone Using Outlook 4
B Trouble Starting Outlook 2010 after Crash Using Outlook 3
U Trouble migrating Contacts (2002) to People (2013) Using Outlook 3
K New to BCM - trouble importing contacts & accounts BCM (Business Contact Manager) 3
B Trying to get old emails from a not working computer but having trouble. Using Outlook 6
M Trouble Importing folders from Outlook 2007 to Outlook 2013 Using Outlook 12
T Outlook 2007 - trouble with alphabetizing when titles are used (ie - Mr.) Using Outlook 0
M Outlook 2010 stuck in Work Offline mode; trouble sending email Using Outlook 1
B Trouble Adding @Outlook.com Email Accounts Using Outlook 3
K Trouble converting the ANSI PST to a Unicode PST Using Outlook 4
U Trouble for sharing Calendar Using Outlook 3
S Trouble setting up Outlook Connector to sync with windows live Using Outlook.com accounts in Outlook 3
N Trouble importing calender information from iPhone into OutLook 2010 Using Outlook 1
J TROUBLE SENDING EMAIL FROM OUTLOOK, NO PROBLEM RECIEVING WHEN WORKING FROM OUT OF TOWN Using Outlook 1
T Trouble with creating database BCM (Business Contact Manager) 1
M having trouble importing excel data into outlook contacts BCM (Business Contact Manager) 1
K Trouble using SaveAs Outlook VBA and Custom Forms 3
M trouble connection to remote database BCM (Business Contact Manager) 1
A Out of Office Improvement Outlook VBA and Custom Forms 0
M Office 2016 Outlook is forgetting passwords Using Outlook 15
D Sending email from Office 365 alias in Outlook Using Outlook 3
J Office 365 erased all of my task views Using Outlook 3
P Categorize in Calendar not listed under tags in Office 365 (Office 2016) Using Outlook 5
L Deleting Office 365 calendar appt w/o emailing invitees Using Outlook 3
D Outlook 2016 Deleting emails without affecting folder structure - Outlook Office 365 Using Outlook 3
L Can signatures synch to Office Portal Using Outlook 1
T I'm thinking about moving from outlook.com to the Outlook I have in my Office 365 Using Outlook 1
Jennifer Murphy Outlook can't connect to Office 365 at resort hotel Using Outlook.com accounts in Outlook 1
J Outlook Office 365 Win 10 how do I control background colors of events? Using Outlook 1
L Outlook Office 365 client: won't remember my setting File, not to collapse ribbon Using Outlook 2
J Migrate from godaddy 365 to office 365 home Using Outlook 8
Microfiche Migration from Office 2016 H&B to Office 365 Using Outlook 0
R How Can I backup office 365 account? Exchange Server Administration 1
