Outlook 2016\365 export specific rules to import in another system
questorfla
Is there a procedure whereby I could export certain settings (specifically the ones under Junk Email Options) to a file so those same settings can be imported into a different account using the same version of Outlook 2016 Exchange. It needs to be as specific as possible and not just Every Rule and Setting in Outlook. If there are any additional procedures covering other similar aspects that might also be used later to import into other Outlook accounts they would be handy to have as well. In this specific case, it is with regard to the Junk Filters under International covering blocked encoding and blocked top level domains from some countries. I am aware that this is an easy block for Spam to bypass but every little bit helps.
It would be nice if I could choose to set "move to a blocked email folder" rather than completely block the emails caught using this method to determine its effectiveness as configured.
Most of the stuff is in the registry - but the safe and blocked lists can be exported to a text file. (They are also in the registry). The only problem with the new versions of outlook is that each account has it's own setting and own registry key - it makes it harder to export the keys and reuse them.
Blocked domains should get sent to the Junk mail folder - of course, you won't know if a junk mail filter would have trapped it anyway.
P Outlook 2016 Client and 365 - Groups Folder Using Outlook 3
mrje1 Outlook 2016 Manual Email Account Setup, what is the Office 365 option etc., and Crashes Using Outlook 0
copperberry Outlook 2013 (desktop) vs Outlook 365/Outlook 2016 Using Outlook 7
glnz Can Word Normal.dotm interfere with Outlook? Office 2016 Using Outlook 5
D Outlook 2016 and Earlier with Office365 in 2021 Using Outlook 3
B Outlook 2016 Retail C2R keeps logging since update? Using Outlook 0
R Microsoft Outlook 2016 - Gmail not sending, asks for password for SMTP, tried different ports Using Outlook 23
M Office 2016 Outlook is forgetting passwords Using Outlook 15
GregS Why is Outlook 2016 mail in Outlook.com? Using Outlook 1
C Outlook 2016/2019 hangs after being open for an extended period Using Outlook 4
A Outlook 2016 in Cached Mode Using Outlook 1
N Outlook 2016 Folder Icons Look Using Outlook 0
GregS Outlook 2016 Outlook 2016 stalls Using Outlook 3
H Outlook 2016 sent over 30 copies of an e-mail with attachments Using Outlook 1
K Outlook 2016 Using Outlook 0
W Search Incomplete Outlook 2016 Using Outlook 5
A Outlook 2016 not synching Using Outlook 4
B The Outlook 2016 Profile that isn't always there Using Outlook 2
