Marco doesn't show up when using Alt-F8
Michiel
Outlook 2013 64 bit
I found a nice script on slipstick website by Diane. Unfortunately I cannot get them to run. I am a bit new at VBA. I want to use the script Reply to a web form generated message. I already have some macros that work. In ThisOutlookSession I have pasted the code above below the other macros. The name SendNew shows up in the right corner where the name of the macros are displayed. But when I save, it doesn't show up when I hit Alt-F8. When I remove Item As Outlook.MailItem from between the brackets, the name SendItem does show up when I hit Alt-F8, but there is an error 424 in the script now. So a bit of a catch 22. I would love some advice on how to solve this. I have googled quite a bit...
This same issue, that a name of a script that I download from the internet shows up in the right top corner, but when I save, it doesn't show up when I hit Alt-F8, happens frequently, so there is something basic there that I don't understand.
The script from Diane:
Sub SendNew(Item As Outlook.MailItem)
Dim Reg1 As Object
Dim M1 As Object
Dim M As Object
Dim strAddress As String
Set Reg1 = CreateObject("VBScript.RegExp")
With Reg1
.Pattern = "(([\w-\.]*\@[\w-\.]*)\s*)"
.IgnoreCase = True
.Global = False
If Reg1.Test(Item.Body) Then
Set M1 = Reg1.Execute(Item.Body)
For Each M In M1
strAddress = M.SubMatches(1)
Dim objMsg As MailItem
Set objMsg = Application.CreateItemFromTemplate("C:\path\to\template.oft")
objMsg.Recipients.Add strAddress
' Copy the original message subject
objMsg.Subject = "Thanks: " & Item.Subject
' use for testing
objMsg.display
' objMsg.Send
This part: Sub SendNew(Item As Outlook.MailItem) means it needs to be called by another macro (or a run a script rule). If you remove the mailitem part, you need to set the item in the macro.
This should work to call the macro for the selected item. If you want it to work with open or selected items, get the function from Outlook VBA: Work with Open Item or Selected Item and use
Set Item = GetCurrentItem()
if you want to use 1 macro, you need to add the dim and set to the original macro (and remove the item as mailitem part)
sub runmacro()
Dim Item As Outlook.MailItem
Set Item = Application.ActiveExplorer.Selection.Item(1)
SendNew Item
end sub
Michiel
Outlook 2013 64 bit
The first part of your explanation I didn't quite follow, but the last part worked for me. :) I pasted your code below the original code, deleted the text between the brackets and works like a charm. Thank you!
J Marco in search of text in subject line Using Outlook 8
J outlook 2007 doesn't let me choose which .pst to search Using Outlook 0
P Outlook Mobile App Doesn't Refresh Inbox Using Outlook 0
GregS Simple calendar sharing doesn't work Using Outlook 6
E Accessing shared outlook folder doesn't work since switch to new outlook/excel Outlook VBA and Custom Forms 11
J Junk mail doesn't work Using Outlook 3
Laurent Duchastel New email setup dialog doesn't allow alias Using Outlook 2
C scanpst.exe doesn't repair .pst file Using Outlook 1
Caio "From" field doesn't show extra email addresses in Outlook 2016. Using Outlook.com accounts in Outlook 6
O Worksheet doesn't show on jumplist Using Outlook 1
C Outlook 2016 doesn't show contacts in address book Using Outlook 2
Diane Poremsky Category Color doesn't Display in Inbox New Slipstick.com Articles 0
S Outlook 2013 doesn't download html messages Using Outlook 0
M Google Apps Mail *SENT* from iPhone doesn't download to Outlook via POP3 Using Outlook 1
P AutoForward Randomly Doesn't fwd emails Using Outlook 3
Diane Poremsky Receive a Reminder When a Message Doesn't Arrive? New Slipstick.com Articles 10
K Macro doesn't recognize local mails from colleagues Outlook VBA and Custom Forms 2
W Filter condition "contains"/"doesn't contain" doesn't always work Using Outlook 10
M Outlook hidden even when open (maximising doesn't fix it) Using Outlook 2
Z outlook 2007 - opening a contact from the search results doesn't use the custom form Using Outlook 10
M Address book doesn't update contacts? Please any help would be great! Exchange Server Administration 4
A yahoo mail doesn't send or receive reliably Using Outlook 1
S VBA to modify appointment item in additional Exchange account doesn't work Using Outlook 0
G Outlook2013 - "From" name doesn't change even when changed in Account Setting Using Outlook 4
T doesn't show up previous info (email, contacts and tasks)after windows up date Using Outlook 0
O Change folder doesn't work Using Outlook 2
G run-time 438: object doesn't support this property or method Using Outlook 2
S MAC outlook doesn't show the meeting organizer detail Using Outlook 0
S Newly added user doesn't show up in GAL but available in OWA, Using Outlook 0
B Archiving of emails doesn't work anymore Using Outlook 3
J outlook rule doesn't run automatically Using Outlook 0
D Outlook 2013 Doesn't Send email from Web Page Unless Outlook Is Open Using Outlook 2
J Calculating the age of an Outlook contact doesn't work Using Outlook 20
J Recipient email address doesn't get underlined Using Outlook 4
G Published Email Form Doesn't Display Text Boxes to the Recipient Using Outlook 0
K Send/Receive All Folders doesn't show Progress status Using Outlook 14
M Rules - daily status (email) doesn't change much daily, save 1 per week how? Using Outlook 1
