Keep Original email unread after autoreply
Hemant Sonawane
Exchange Server 2010
Hi Expert,
Below Autoreply with template code works fine. I just want after replying, original massage should be unread
please help with change in macro.
Sub AutoReplywithTemplate(Item As Outlook.MailItem)
Dim oRespond As Outlook.MailItem
' Use this for a real reply
' Set oRespond = Item.Reply
' This sends a response back using a template
Set oRespond = Application.CreateItemFromTemplate("C:\path\to\template.oft")
With oRespond
.Recipients.Add Item.SenderEmailAddress
.Subject = "Your Subject Goes Here"
.HTMLBody = "Your reply text goes here." & vbCrLf & _
"---- original body below ---" & vbCrLf & _
Item.HTMLBody & vbCrLf & _
"---- Template body below ---" & _
vbCrLf & oRespond.HTMLBody
' includes the original message as an attachment
.Attachments.Add Item
' use this for testing, change to .send once you have it working as desired
.Display
Set oRespond = Nothing
Hemant
R keep track of the original sender Outlook VBA and Custom Forms 3
kburrows Reset Date to Keep Tasks from Archiving Using Outlook 9
T Why is every new email pinned (to keep it on top)? Windows 10 Using Outlook 6
CWM030 Outlook 2016 with imap emails keep Resurrecting themselves? Using Outlook 5
Scorpion New Contacts keep coming up as company Using Outlook 1
R Can't keep emails synced on various devices Using Outlook.com accounts in Outlook 4
piusg 2013: Task Views keep disappearing Using Outlook 4
Dan Badur How can I keep indenting OFF on replies in Outlook 2013? Using Outlook 1
S how to keep "To" when move sent emails to other folder Using Outlook 1
K Deleted emails keep coming back Using Outlook 3
A How to add personal notes to a meeting - and keep them if update sent? Using Outlook 1
A outlook trying to keep sending Using Outlook 1
B Closing Exchange service, how to keep all calendar and mail data? Exchange Server Administration 0
D How to keep Outlook 7 open to full screen Using Outlook 2
S How do I keep my old PST file as default Exchange Server Administration 1
Z Keep Unread Messages in same folder Using Outlook 2
L Oulook always "disconnected" how do I keep it open all of the time? Using Outlook 1
P emails with attachments keep sending... HELP!!! Using Outlook 4
M How do you keep sent emails in the PST folder in outlook 2013 Using Outlook 1
N Contact Groups - names keep changing from Contacts to AddressBook Using Outlook 5
M Reminders keep coming to users' calendar Exchange Server Administration 1
L Outlook 2010 - Keep getting "Corrupted File" Msgs Using Outlook 4
S Reminders keep popping up, even after dismissing them Using Outlook 9
P deleted items keep reappearing in my deleted folder Using Outlook 4
P Stationary and view layout keep changing after reboot? Using Outlook 1
Y MICROSOFT OUTLOOK 2007 - i KEEP GETTING THE "ENTER NETWORK PASSWORD" BOX POPPING UP - IT IS ALREADY Using Outlook 4
A How to keep all conversations expanded? Using Outlook 3
S Deleted messages keep coming back Using Outlook 7
A Keep format of message in the body Outlook VBA and Custom Forms 1
R How do I keep old calendar events from disappearing? BCM (Business Contact Manager) 2
S Email Generated from another program and then edited sends original email. Using Outlook 2
T Original email text not shown when replying or forwarding the email. Using Outlook 9
