help with Item/Inspector close event
DDIT
I am using the code exactly as shown here OutlookCode.com :: Send a standard mail message from a custom form. to overcome the issue with sending custom forms.
Everything works well, except the Item_Close function, which returns the error "The item's properties and methods cannot be used inside this event procedure"
The line in question is
objInsp.Close 1
however I have also tried
objInsp.Close(olDiscard)
...and...
objInsp.Close olDiscard
but the error is the same. There is lots of discussion about this being broken in Outlook 2003 and 2007, but later fixed with a hotfix. I cannot find a similar hotfix for 2010, so assume it made it's way into the final build or a service pack?
Either way, could someone help troubleshoot this for me, or tell me a work around??
Many thanks.
DDIT
Forgot to mention, I am using Outlook 2010 SP2, a mix of x32 and x64.
G "Full Item has not been downloaded" message. HELP! Using Outlook.com accounts in Outlook 4
B HELP! Using Outlook 4
M Winmail. dat - HELP Using Outlook 2
Diane Poremsky Help! My Contacts are being updated! New Slipstick.com Articles 0
B VBA Help Email that will save as draft and send as attachment Outlook VBA and Custom Forms 3
J Can Anyone Help?? Outlook VBA and Custom Forms 1
G Looking for help with our Organization Forms Library Outlook VBA and Custom Forms 1
A newb outlook macro help Outlook VBA and Custom Forms 1
X Help with custom form which is very similar to Tasks Outlook VBA and Custom Forms 6
P Outlook 2010: Missing tab - "Format/Picture Tools" HELP! Using Outlook 3
L Looking for help - want to try an alternative to Outlook? Outlook Wishlist 0
M Help! Can't set up IMAP for gmail Using Outlook 2
