Open a folder / subfolder of a PST in single click
Bamerand
Outlook 2013 32 bit
Hello all,
I have migrated a lot of folders from my account to an PST archive, there are over 100 folders that were moved. I need to access them constantly, so, I jump between inbox of my account to the PST archive, however, it is a bit annoying as I need to expand / collapse the folders of PST archive. I have been using FAVORITES to access some certain folder from the PST archive or used SHORTCUTS (see the attached screenshots), however, those are of limited use. Recently I have discovered a nice article by Danny De Roovere, which outlines nicely on how to move mail items to a folder via one single click. My question is does anyone know of in a way similar to what Danny De Roovere had made, however, to make access some folder instead of moving email message. That is I need to open a certain folder / sub-folders from either PST archive and / or account in one single click. Any ideas?
Michael Bauer
Without knowing the mentioned article, you can move emails based on criteria like subject, sender, etc. That doesn't work for opening any folder. That is for a one-click solution you'll need 1 button per folder.
Bamerand
Outlook 2013 32 bit
Hello Michael,
I have attached the file (MS Outlook - How to Move Mail Items to a Folder via One Single Click.pdf), this is one is very fancy to use to move email to pre-defined folders. I was wondering if anyone knows of a code that is executed in the similar way and created a panel with folder name, but for opening / accessing the folder, instead of moving the emails to the designated folders.
oliv-
Hi ,
Command Bars were deprecated with Outlook 2010
Set CommandBar = myExplorer.CommandBars.add(Name:="Quick Access Folder", _
Position:=msoBarFloating, Temporary:=True)
Bamerand
Outlook 2013 32 bit
Meaning there is nothing can be done about creating custom command bar?
B Saved emails in folders I created on left of screen are being erased as I open each folder Using Outlook 0
V Open Outlook Calendar and Tasks views with Folder pane off Using Outlook 2
L Outlook 2007 Open Folder From a Contact Using Outlook 22
L Outlook 2007 Macro Open Contact Folder Using Outlook 7
Y (Shared Folder) Using the preview pane to open and close a fax, without opening the email itself Using Outlook 1
L Open Contact From Folder Outlook VBA and Custom Forms 10
A How to open .msg file from Hard disk folder? Using Outlook 3
S Code to open folder Using Outlook 11
L Macro to Open a Contact Folder Using Outlook 15
D Unable to open hotmail, error hotmail.ost is not an offline folder file Using Outlook 3
S When opening a folder, it takes a long time to open. Using Outlook 1
M Cannot display the folder. Outlook cannot open this item. The item may be damaged. __ Using Outlook 1
M Open Outlook 2010 Archieve Folder Exchange Server Administration 1
J How do I find which folder an open email resides in? Using Outlook 4
J Cannot open your default e-mail folder. The file "C\Users\Jim\AppData\Local\Microsoft\Outlook\Outlo Using Outlook 2
J Make Outlook 2003 open at the Unread mail folder Using Outlook 1
B Tried to set outlook and now all i get is box telling me I cannot open default email folder Using Outlook 2
Y Set Outlook to open Inbox folder by default Using Outlook 1
R 'Folder in use' or 'Can't open Folder' Using Outlook 1
S Cannot Open This Folder Using Outlook 1
V After compacting my pst file, I can't open Sent Items folder. Error message says, "the messaging int Using Outlook 3
N Receiving messages & unable to open deleted item folder Using Outlook 2
T unable to open default e-mail folder Using Outlook 1
A Outlook 2007 Trying to open other users Folder that has hide from exchange address lists on the account Using Outlook 4
A Messages move to Junk E-mail folder only when I open them Using Outlook 2
A MS Outlook won't load... Error message>>> "Cannot open your default e-mail folder:" Using Outlook 4
J Cannot open my contact folder and therefore the contacts have disappeared. Using Outlook 3
V Outlook will not open... Says Outlook2.pst is not a personal folder file Using Outlook 9
W Cannot open your default e-mail folder. Using Outlook 3
A How to open a specific link automatically with outlook 2016 Outlook VBA and Custom Forms 5
sahameed82 SharePoint calendar directly open in Outlook Using Outlook 0
C Outlook 2016/2019 hangs after being open for an extended period Using Outlook 4
C Can't Open Outlook 365 Using Outlook 0
D after delete mail, open the next one Outlook VBA and Custom Forms 0
M outlook won't open! Using Outlook 1
M other user's mailbox won't open, forms disappeared Using Outlook 42
D Add Tetxbox at form open Outlook VBA and Custom Forms 1
