Updated custom form not showing with old items
abhijeet
Outlook 2013 32 bit
I am customizing outlook appointment form. I have added few fields in P2. Published the form to my personal form library as ABC.
On my calendar I have created few appointments using this custom form.
Now
When I modified my existing form and changed some of the fields and published again to personal form library with same name as ABC. If I create new appointment it works fine however for old appointments it still shows the old form.
What should I do to reflect the updated form to old items.
Please help.
always set version number and increment it on the properties tab before republishing updates - this prevents corrupting the forms cache. To fix - go to file, options, advanced, manage forms button and clear the cache.
When you use version # and update the form, the new form will be used without clearing the cache.
abhijeet
Outlook 2013 32 bit
Thanks Diane Poremsky it worked for me. You are the best.
A Sending contact vcards sends older version instead of updated version Using Outlook 4
M Multiple User Defined Fields that can be added, changed, updated using VBA and user form Outlook VBA and Custom Forms 0
Diane Poremsky Help! My Contacts are being updated! Using Outlook 0
Rory Campion Not getting a warning when a shared calendar item has been updated by someone else Using Outlook 2
C BCM updated records not refreshing on other PCs BCM (Business Contact Manager) 2
V iCloud Configuring @me.com in Outlook (updated) Using Outlook 1
J Outlook 2010 - missing "Updated: ... " in subject text after calendar update Using Outlook 2
A Identifiying who changed or updated an appointment in Exchange 2007 Exchange Server Administration 7
G recurring meeting exceptions count not updated Outlook VBA and Custom Forms 3
T Trickle down info from updated Accounts to Contacts BCM (Business Contact Manager) 1
N "Perform a Custom Action" Outlook VBA and Custom Forms 0
