Best practice for catching mailitem.events
oliv-
What is the best pratice for catching Mailitem events ? (response, forward, etc...)
i saw in this article : VBA Sample: Do Something When Reply is Clicked
this code
Option Explicit
Private WithEvents oExpl As Explorer
Private WithEvents oItem As MailItem
Private bDiscardEvents As Boolean
Dim oResponse As MailItem
   Set oExpl = Application.ActiveExplorer
   bDiscardEvents = False
Private Sub oExpl_SelectionChange()
   Set oItem = oExpl.Selection.Item(1)
' Reply
Private Sub oItem_Reply(ByVal Response As Object, Cancel As Boolean)
   Cancel = True
   bDiscardEvents = True
Set oResponse = oItem.Reply
afterReply
Private Sub oItem_Forward(ByVal Response As Object, Cancel As Boolean)
   Cancel = True
Set oResponse = oItem.Forward
afterReply
And I use this one :
ThisOutlookSession
Private m_MyEmails As VBA.Collection
Private m_lNextKeyEmails As Long
Private Sub Application_ItemLoad(ByVal item As Object)
' Procedure : Application_ItemLoad
' Author    : Oliv
' Date      : 07/03/2016
' Purpose   : EMAIL WRAPPER / Receive Events of Multiple Emails
' BASED ON : http://www.vboffice.net/en/developers/inspector-wrapper-receive-events-of-multiple-emails/
    Dim oMail As cMail
    If m_MyEmails Is Nothing Then Set m_MyEmails = New VBA.Collection
    Set oMail = New cMail
    If item.Class = olMail Then
        If oMail.Init(item, CStr(m_lNextKeyEmails)) Then
            m_MyEmails.Add oMail, CStr(m_lNextKeyEmails)
            m_lNextKeyEmails = m_lNextKeyEmails + 1
Friend Property Get MyEmails() As VBA.Collection
    Set MyEmails = m_MyEmails
End Property
Class module
' Module    : cMail
' Author    : Oliv
' Date      : 07/03/2016 17:49
Private WithEvents m_Mail As Outlook.MailItem
Private m_IsClosed As Boolean
Private m_sKey As String
Friend Function Init(oEmail As Outlook.MailItem, sKey As String) As Boolean
    Dim obj As Object
    If Not oEmail Is Nothing Then
        Set m_Mail = oEmail
        m_sKey = sKey
        Init = True
End Function
Private Sub Class_Terminate()
    CloseEmail
Friend Sub CloseEmail()
    If m_IsClosed = False Then
        m_IsClosed = True
        ThisOutlookSession.MyEmails.Remove m_sKey
        Set m_Mail = Nothing
Private Sub m_Mail_Close(Cancel As Boolean)
    CloseEmail
Private Sub m_Mail_Forward(ByVal Forward As Object, Cancel As Boolean)
    If Forward.Class = olMail And OptResponseHTML Then
        MsgBox "fire m_Mail_Forward" & vbCr & Forward.BodyFormat
Horsepower Email best practice Using Outlook 3
I Best Practice for Large Messages NDRs? Exchange Server Administration 4
D Exchange Best Practice for DEV/TEST/PROD Exchange Server Administration 2
Rupert Dragwater What is the best way to back up pst Using Outlook 4
Diane Poremsky The Best Outlook Store Add-ins Contest New Slipstick.com Articles 0
X Best utility for repairing PST files? Using Outlook 3
D a suggestion ...sent with the best intentions Using Outlook 1
M How best to track OUTGOING referrals? BCM (Business Contact Manager) 2
M best duplicate contact remover? Using Outlook 6
G what is the best way to organize outlook contacts Using Outlook 1
D What would be the best strategy? Using Outlook 3
J Best way to move form old to new, larger pst? Using Outlook 2
M Best way to move outlook? Using Outlook 1
R Best way to share outlook calendar with 10 laptops Using Outlook 9
N Outlook 2010, Categories, best way to filter contacts? Using Outlook 5
F Best Non MS Exchange 2010 book for beginners? Exchange Server Administration 7
S CAS/MBX reboot best practices. Exchange Server Administration 7
L best rule/macro to send emails from many people/orgs to same folder Using Outlook 3
R Any "Best Practices" for a test/developer Exchange 2010 server? Exchange Server Administration 2
C Best way to effectively back up Outlook Calendar (and save Categories) and Email as well???? Using Outlook 6
R Best practices for creating "Equipment" mailbox resources? Using Outlook 1
M Exchange 2010: What to monitor - best practices Exchange Server Administration 4
K Best case scenerio to reduce disk space usage Exchange Server Administration 5
B Best way to get a pick-list on a form? Outlook VBA and Custom Forms 1
M Best way to distribute VBA project Outlook VBA and Custom Forms 4
T Is Explorer.FolderSwitch the best event for hiding commandbarbutton? Outlook VBA and Custom Forms 5
A Where are the Step by Step Microsoft outlook 2010 practice files? Using Outlook 3
U Catching ModuleSwitch events after "open in new window" Outlook VBA and Custom Forms 2
