Change default from english to danish ......
Lena C
Outlook 2007
Exchange Server 2013
I have a problem with a Outlook 2007. I am in Denmark and we use a Danish outlook. One friend has copied an English version to her outlook 2007 using a .pst. Now we have the English as default but we want the Danish to de default. I cannot make a .pst only containing the Danish folders.
How can I delete the English default folders and replace them with the Danish?
Or make the Danish the defalut and then delete the English.
All mails have been moved to the Danish inbox, meetings have been moved to the Danish calender and so on.
The problem is: she writs mails from the Danish inbox but the sent mail is saved in the English Sent folder. '
When she receives a meeting invitation the meeting is saved in the English Calender and not to the Danish kalender.
Need advice to change the default to be the Danish folders.
Regards Lena
Lena C
Outlook 2007
Yes. It does not help.
The problem is that the English calender, sent folder, draft, contacts is default.
It's a real mess with both English and Danish folder.
What language is Windows? I'm assuming you have both Danish and English languages installed but English is set as default? If everything is Danish, i think the switch would work, but something is making Outlook think English is default.
If you add a new pst to the profile and set it as default, what happens? If it turns out the way you want, you can either import the old pst or move stuff from the old pst to the new.
Lena C
Outlook 2007
You mean import an "empty" .pst file and then import the real .pst and one by one import the right folders?
Windows is Danish.
Lena C
Outlook 2007
Change of .pst and move folders helped. And reset the right .pst as default.
C Change default colors for conditional formatting Using Outlook 2
Diane Poremsky To Change the Default E-mail Program in Windows New Slipstick.com Articles 0
Davzell Change default pop3 account with script, prf or registery ? Outlook VBA and Custom Forms 0
Diane Poremsky Change the All Day Event Default Free/Busy to "Busy" New Slipstick.com Articles 3
M Change default "automatically test account settings when Next is clicked" Using Outlook 1
David Rahrer Change default Junk E-Mail folder Using Outlook 6
C Change the default sent folder Outlook VBA and Custom Forms 1
JulieB Default data file won't change Using Outlook 6
ogodt Change Default contact form and import from Excel 2010 Using Outlook 1
A iCloud add-on for Outlook: Reminder for new appointment is set to 'None' by default. How to change? Using Outlook 6
B Change default email for address book Using Outlook 1
J Change Default View - Color and font Using Outlook 3
C Change default reminder time for contacts Using Outlook 2
S CHANGE DEFAULT VIEW FOR CONTACT (People) SEARCH - Outlook 2013 Using Outlook 3
M Change default Current View on People Using Outlook 1
T How to change default search engine in Outlook 2013? Using Outlook 3
J How to change my default calendar...? Using Outlook 1
H Outlook default landscape need to change to portrait Using Outlook 1
K Change the default Archive location via GPO in Outlook 2010 Using Outlook 3
F Change default value of date/time type from "None" to Blank Using Outlook 1
G Default Account Change Using Outlook 5
O Exchange + pst: Can I change the default Outlook calendar/tasks/account? Exchange Server Administration 2
S change default contact list in Outlook 2010 to "contacts" rather than "global" Exchange Server Administration 1
M How do I change the default map from Bing to Google in Outlook 2003? Using Outlook 23
K Change default "Display As" for contact email addresses Using Outlook 1
G how to change default calendar view to show this week and future weeks? Using Outlook 1
J How To Change Default View of Tabs in Outlook 2010 Using Outlook 4
H How to make hourglass and change back to default in Outlook class ? Outlook VBA and Custom Forms 3
D How to change account used for replies from default Outlook VBA and Custom Forms 7
C How do I change the default "Add to Outlook Contacts" Folder Using Outlook 6
D RE: How do you change the default insert file path in outlook? Using Outlook 11
V change the Default email Delivery Location Outlook VBA and Custom Forms 3
C How do I change the default character spacing in Outlook e-mail? Using Outlook 3
M Default settings for "Display as" Change? Outlook VBA and Custom Forms 8
D Change Microsoft Account password - what to do to update on all devices Using Outlook 4
R How to Change Margins In Google Docs...? New Slipstick.com Articles 0
D Change senders title Using Outlook 1
