Auto Forward
zcrl0c
Outlook 2013 64 bit
I'm looking for a script to run in an Auto Forward Rule. Something that strips out the recipients email addresses( can be quite lengthy) prior to sending the email to an Outlook Distribution List. I found one here on this site - but can't find the thread now.
zcrl0c
Outlook 2013 64 bit
Not quite. The email is being sent to myself and along list of other folks. I have Outlook set up to Auto Forward to an internal Contact list inside my company. What I'd like to do is remove all the "other folks" email addresses prior to it being Forwarded.
It's work with a little tweaking. Remove the first two lines that change the subject and add these lines after the recipients line.
myForward.body = item.body
myforward.subject = item.subject 'if you want to remove the FW
R Auto-create receipt from email and forward to payer Using Outlook 3
L Auto Forward without presenting the original sender Outlook VBA and Custom Forms 1
J Custom Forms Don't Always Auto-Forward From Public Folder Using Outlook 0
K How to auto truncate a message to forward with Outlook Rules Using Outlook 6
