How to Run a Script IN AN ADDIN with Outlook's Rules and Alerts
oliv-
I want to run a script in a Rule, it's ok if the script is in the VBAPROJECT, but how to do that if is in an OUTLOOK ADDIN ?
oliv-
Ok Michael thank you for your help, i will use a folder to trigger my treatment.
Diane Poremsky Run a Script Rule: Send a New Message when a Message Arrives New Slipstick.com Articles 2
L Outlook 2007 Macro to Run a Script From a Contact Form Using Outlook 41
E run script fails suddenly Using Outlook 3
L Run A Script not listed in rules wizard Outlook VBA and Custom Forms 12
L Run script rule not exectued for first few mails Outlook VBA and Custom Forms 2
B run scripts Using Outlook 1
P errors appear every time I run SCANPST Using Outlook 3
J VBA Run When Reply Outlook VBA and Custom Forms 4
Diane Poremsky Using Scanpst in Outlook Click to Run New Slipstick.com Articles 0
B Can't run macro from QAT when emailing from Acrobat Outlook VBA and Custom Forms 0
D How to Run a Report Based on Age of Inbox Items Outlook VBA and Custom Forms 0
M Office 365 Click to run BCM (Business Contact Manager) 0
K Revert AutoArchive settings via GPO (Run Autoarchive every...) Using Outlook 4
