VBA to extract email (fields and body) to Excel
Outlook Rookie
Outlook 2013 64 bit
Hi All,
I receive routine confirmation messages with details and want to extract some of the text into Excel.
Can I please have a VBA script that copies the key information (please see sample) and pastes it in a specified workbook (please see sample).
There is a lot more information in the email, but I only need some related info.
I’ve attached two sample files. One of the email, and the other of a workbook where I want the information to be pasted. This is a running record, so the information should be pasted into the next available row.
I am using MS 2007 Excel and Outlook.
Can anyone assist me please? Please make your instructions as detailed as possible (as I am not very technical).
OR
  • Sample Email for export to Excel.pdf
  • Sample Workbook for Outlook VBA to export email details to Excel workbook.pdf
Outlook Rookie
Outlook 2013 64 bit
See Use a macro to copy data in Outlook email to Excel workbook - this is used in a run a script rule.
Use RegEx to extract text from an Outlook email message - the second macro on this page shows how to get multiple values.
Thank you for your fast replies.
I tried the codes but came up with Compile error: Ambiguous name detected: CopyToExcel.
Also, since I am really very basic with code, please post detailed instructions. There are other saved macros fyi.
OR
This: Compile error: Ambiguous name detected: CopyToExcel. means you have two macros with the same name. Add a 2 to the end of this one to fix the error.
Outlook Rookie
Outlook 2013 64 bit
I'm now getting a Compile error: Invalid inside procedure at the Option Explicit.. :(
post the code you are using. That error usually means there is a problem with the way a global variable is set.
Outlook Rookie
Outlook 2013 64 bit
Please note the brackets to indicate that the path/folder/file is included there
CopyToExcel code sample
Option Explicit
Private Const xlUp As Long = -4162
Sub CopyToExcel(olItem As Outlook.MailItem)
Dim xlApp As Object
Dim xlWB As Object
Dim xlSheet As Object
Dim vText, vText2, vText3, vText4, vText5 As Variant
Dim sText As String
Dim rCount As Long
Dim bXStarted As Boolean
Dim enviro As String
Dim strPath As String
Dim Reg1 As Object
Dim M1 As Object
Dim M As Object
'the path of the workbook
strPath = enviro & “the Path is entered here "
Set xlApp = GetObject(, "Excel.Application")
If Err <> 0 Then
Application.StatusBar = "Please wait while Excel source is opened ... "
bXStarted = True
On Error GoTo 0
'Open the workbook to input the data
Set xlWB = xlApp.Workbooks.Open(strPath)
Set xlSheet = xlWB.Sheets("Test")
Set olItem = Application.ActiveExplorer().Selection(1)
'Find the next empty line of the worksheet
rCount = xlSheet.Range("B" & xlSheet.Rows.Count).End(xlUp).Row
rCount = rCount + 1
sText = olItem.Body
Set Reg1 = CreateObject("VBScript.RegExp")
' \s* = invisible spaces
' \d* = match digits
' \w* = match alphanumeric
With Reg1
.Pattern = "((P130\w*)\s*(\w*)\s*(\w*)\s*(\w*)\s*([\d-\.]*))"
If Reg1.test(sText) Then
' each "(\w*)" and the "(\d)" are assigned a vText variable
Set M1 = Reg1.Execute(sText)
For Each M In M1
vText = Trim(M.SubMatches(1))
vText2 = Trim(M.SubMatches(2))
vText3 = Trim(M.SubMatches(3))
vText4 = Trim(M.SubMatches(4))
vText5 = Trim(M.SubMatches(5))
xlSheet.Range("B" & rCount) = vText
xlSheet.Range("c" & rCount) = vText2
xlSheet.Range("d" & rCount) = vText3
xlSheet.Range("e" & rCount) = vText4
xlSheet.Range("f" & rCount) = vText5
xlWB.Close 1
If bXStarted Then
xlApp.Quit
Set M = Nothing
Set M1 = Nothing
Set Reg1 = Nothing
Set xlApp = Nothing
Set xlWB = Nothing
Set xlSheet = Nothing
it might be nothing (but goofiness here), but make sure the quote is correct on the path line - it needs to be a straight quote on the left, not the "smart quote".
Outlook Rookie
Outlook 2013 64 bit
Thank you for replying.
I worked on the code as below, with only trial and error and no, repeat, no VBA knowledge.
Basically, what I need is this. For a specific Outlook message (not all the messages in a folder/Inbox), when I run the code it should open a specific Excel file (path specified), and enter the fields in the next available row AFTER the title or header fields. The row titles should not be repeated, just the corresponding entries and so I have a log in Excel of related messages.
The code below gives me a “Compile Error: Expected Array” at this line
If Not (olItems(x).Subject, at the “olItems(x) portion.
Can you please help me with this?
OR
Option Explicit
Sub CopyToExcel()
Dim xlApp As Object
Dim xlWB As Object
Dim rCount As Long
Dim Selection As Selection
Dim olItem As Outlook.MailItem
Dim obj As Object
Dim strColB, strColC, strColD, strColE, strColF As String
' Get Excel set up
strPath = enviro & "path will be here"
If Err <> 0 Then
bXStarted = True
On Error GoTo 0
Set xlWB = xlApp.Workbooks.Open("path will be here")
Set xlSheet = xlWB.Sheets("Test1")
' Process the message record
rCount = xlSheet.Range("B" & xlSheet.Rows.Count).End(-4162).Row
' get the values from outlook
For Each obj In Selection
Set olItem = obj
'collect the fields
strColB = olItem.SenderName
strColC = olItem.SenderEmailAddress
strColD = olItem.Body
strColE = olItem.To
strColF = olItem.ReceivedTime
'write them in the excel sheet
x = 2
arrHeaders = Array("Date Created", "Date Received", "Subject", "Sender", "Sender's Email", "CC", "Sender's Email Type", "Message Size", "Unread?")
xlWB.Worksheets(1).Range("A1").Resize(1, UBound(arrHeaders)).Value = ""
Do
With xlWB.Worksheets(1)
If Not (olItems(x).Subject = "" And olItems(x).CreationTime = "") Then
Range("A1").Resize(1, UBound(arrHeaders) + 1) = arrHeaders
Cells(x, 1).Value = olItems(x).CreationTime
Cells(x, 2).Value = olItems(x).ReceivedTime
Cells(x, 3).Value = olItems(x).Subject
Cells(x, 4).Value = olItems(x).SenderName
Cells(x, 5).Value = olItems(x).SenderEmailAddress
Cells(x, 6).Value = olItems(x).CC
Cells(x, 7).Value = olItems(x).SenderEmailType 'Ex: Internal server; SMTP or SMFP? Internet Server
Cells(x, 8).Value = Format((olItems(x).Size / 1024) / 1024, "#,##0.00") & "MB"
Cells(x, 9).Value = olItems(x).CreationTime
x = x + 1
Set olItem = Nothing
Set obj = Nothing
Set currentExplorer = Nothing
Set xlApp = Nothing
Set xlWB = Nothing
I'm not sure why the array error, you're setting x = 2 - the rows should be rCount:
So you'd use
Cells(rCount, 1).Value = ....
Then remove this line:
and this:
You're also using X to identify the item: olItems(x).
The values were set earlier:
strColE = olItem.To
use either of these formats instead:
Cells(x, 1).Value = olItem.CreationTime
Cells(x, 2).Value = strColF
Outlook Rookie
Outlook 2013 64 bit
Thank you again for your help.
Sorry, I tried to understand your message as best I could and made the corrections below. I was getting a syntax error and found that I had to remove olItems and replace it with a singular “olItem”.
Now I am getting the Compile Error: Do Without Loop at the End Sub
Can you please fix the code?
Option Explicit
Sub CopyToExcel()
Dim xlApp As Object
Dim xlWB As Object
Dim rCount As Long
Dim obj As Object
' Get Excel set up
strPath = enviro & "\\RC14dp13\LDS\Staff Folders\Yola Rego\usb\Excel\Excel and VBA\VBA Outlook\20160425 Cafeteria Orders Consolidated.xlsx"
If Err <> 0 Then
bXStarted = True
On Error GoTo 0
Set olItem = obj
'collect the fields
Cells(x, 1).Value = olItem.SenderName
Cells(x, 1).Value = olItem.SenderEmailAddress
Cells(x, 1).Value = olItem.Body
Cells(x, 1).Value = olItem.To
Cells(x, 1).Value = olItem.ReceivedTime
x = 2
xlWB.Worksheets (1)
Do
If Not (olItem(x).Subject = "" And olItem(x).CreationTime = "") Then
Cells(x, 1).Value = olItem(x).CreationTime
Cells(x, 2).Value = olItem(x).ReceivedTime
Cells(x, 3).Value = olItem(x).Subject
Cells(x, 4).Value = olItem(x).SenderName
Cells(x, 5).Value = olItem(x).SenderEmailAddress
Cells(x, 6).Value = olItem(x).CC
Cells(x, 7).Value = olItem(x).SenderEmailType 'Ex: Internal server; SMTP or SMFP? Internet Server
Cells(x, 8).Value = Format((olItem(x).Size / 1024) / 1024, "#,##0.00") & "MB"
Cells(x, 9).Value = olItem(x).CreationTime
x = x + 1
Set obj = Nothing
Set xlApp = Nothing
Set xlWB = Nothing
The error is tell you that you have a Do but no corresponding Loop at the end (after the end with. )
It looks there are other errors -
This is telling strpath that it's c:\users\username\\RC14dp13\LDS...
Assuming \\RC14dp13\ is a shared server, remove the enviro part:
strPath = "\\RC14dp13\LDS\Staff Folders\Yola Rego\usb\Excel\Excel and VBA\VBA Outlook\20160425 Cafeteria Orders Consolidated.xlsx"
this should use the strpath you set above:
Set xlWB = xlApp.Workbooks.Open(strpath)
I'm not sure what this is supposed to do:
since you also have this:
If you need to keep adding to the same sheet, use rCount - it identifies the last used cell and starts there.
Cells(rCount, 1).Value = olItem(x).CreationTime
Cells(rCount, 2).Value = olItem(x).ReceivedTime
Cells(rCount, 3).Value = olItem(x).Subject
Cells(rCount, 4).Value = olItem(x).SenderName
Cells(rCount, 5).Value = olItem(x).SenderEmailAddress
Cells(rCount, 6).Value = olItem(x).CC
Cells(rCount, 7).Value = olItem(x).SenderEmailType 'Ex: Internal server; SMTP or SMFP? Internet Server
Cells(rCount, 8).Value = Format((olItem(x).Size / 1024) / 1024, "#,##0.00") & "MB"
Cells(rCount, 9).Value = olItem(x).CreationTime
Outlook Rookie
Outlook 2013 64 bit
Thank you for the revisions. Sorry for the delay in my response and I will try them soon.
BTW, I sent a couple of messages to the Forum Administrators and have not heard back. Are you able to contact them or check for me, please?
OR
Outlook Rookie
Outlook 2013 64 bit
Can you please advise the forum administrator to respond to my message sent via contact me
D VBA Script to extract text matching specific criteria Outlook VBA and Custom Forms 1
R Limiting length of saved attachment in VBA Outlook VBA and Custom Forms 2
B VBA to Collapse Task Folder Groups Outlook VBA and Custom Forms 1
shrydvd vba to secure zip attachments Outlook VBA and Custom Forms 3
