Auto Preview Attachment in Inspector Reading Pane
B Caspe
I'd like to create a user form that would work with the mail Inspector object. The form would have up/down arrows that would let me scroll through mail items, viewing them in the Inspector (the same functionality as the arrows already available on the QAT). And also a command button to forward items if desired.
Hoping I can work out the above, my question here is --- as I scroll through the mail items, can I use vba to automatically display attachments in the Inspector reading pane / preview pane.
If it makes a difference, the attachments would be .pdf files, one on each email.
Outlook 2010
Thanks for any assistance.
So what you really want is attachments automatically previewed? Or at least. all attachments previewed when you click a button.
This code sample does it for images - Viewing Multiple Picture Attachments in Outlook 2003 I'm not sure if you can do it with pdf files, but that code might be a start.
