send reminder if no reply received on first or original email using macro
Hemant Sonawane
Exchange Server 2010
Hi Experts
I need macro which will send reminder if no reply received on first or original email.
Please help.
Hemant Sonawane
There is at least one utility that can do this - Follow-Up Reminders - Sperry Software - at $30, it's probably cheaper than trying to do it with macros (and it will be more efficient).
I don't have any macros that do this... i would probably set a flag on the sent message then check incoming messages that begin with RE: for a match in the sent folder and turn the reminder off if a match is found.
Or... just set the reminder on the sent message then use a reminder macro to send a message when the reminder fires... but you'd either need to mark the sent item complete yourself or use a macro to match the incoming message to the sent. If you use conversation view, marking the sent item complete yourself should be easy enough.
M VBA to send reminder email if no response Using Outlook 13
M Send an Email When a Reminder Fires Outlook VBA and Custom Forms 1
E Send a Reminder/Task to certain Email Recipient Using Outlook 5
Diane Poremsky Send an Email When a Reminder Fires New Slipstick.com Articles 0
E macro to send an email when an EMAIL reminder fires Using Outlook 1
M I have to send out a meeting invite to others that starts up a URL on reminder Using Outlook 0
F Send As a Gmail account via outlook Web Using Outlook 3
S Meeting Invite arrives from Wrong ("send-as") Sender Using Outlook 1
M Can't send email in outlook.com Using Outlook 9
R Can't Send calendar share invite Using Outlook 5
R Can't send messages to groups in Outlook Using Outlook 2
J Updating existing entry on shared calendar wants to send update from delegate Using Outlook 0
soadfan Outlook won't send e-mail when offline Outlook VBA and Custom Forms 19
K Delay Send and Mail Merge Outlook VBA and Custom Forms 4
L How to automaticlly Send/Receive every 3 mins but override send if send/receive is pressed Using Outlook 2
D Delay Send not working Using Outlook 3
F Send multiple batch tasks to single person Using Outlook 3
R Prompt asking the user to send email to folder as *.msg file Outlook VBA and Custom Forms 1
D Default Send Account that Works? Using Outlook 0
