VBA macro printing attachments in shared mailbox
David Lynch
I've just tried creating my first macro using examples from various other posts.
We have a shared mailbox and want to be able to trigger a macro (to print attachments) when a message is moved from the Inbox of the shared mailbox to another folder within the shared mailbox. I've created the macro on my PC and it works fine.
However, when testing I've noticed that if another user moves a message into this folder it also runs the macro that I have created. My assumption had been that I would need to add the same macro to each user's Outlook for this to work. If that's not the case what will happen if I do have the same macro on each user's machine? Will it run the same macro multiple times and therefore print multiple times? I don't want to have the macro running on a single machine as it will obviously cause problems when that machine isn't switched on.
I have a second issue also. If the attachments print successfully I want to move the email into a sub-folder (also on the shared mailbox) but can't get this to work. Any examples of moving messages between folders on a shared mailbox would be appreciated.
IHowever, when testing I've noticed that if another user moves a message into this folder it also runs the macro that I have created. My assumption had been that I would need to add the same macro to each user's Outlook for this to work. If that's not the case what will happen if I do have the same macro on each user's machine? Will it run the same macro multiple times and therefore print multiple times? I don't want to have the macro running on a single machine as it will obviously cause problems when that machine isn't switched on.
The macro watches for new items in a folder - it only needs to run on one computer if you are watching a shared mailbox. If the macro is on more than one computer, it will likely run when each computer detects a change. (Test it to verify.) You can try setting flags - the macro on the computer where it's moved should fire first. You might be able to use the changed by field and run the macro only if the current user is the one who changed it... but it really depends on what is in the changed by field initially and if outlook changes it to the user's account. Replies and flags will change it - but just moving a message or marking as read isn't changing it here.
What code are you using to identify the shared mailbox? After printing, you should be able to set a folder them move the mail object to it.
J Macro only runs within VBA Editor Outlook VBA and Custom Forms 2
S Outlook 7 VBA macro for multiple filing Outlook VBA and Custom Forms 1
Philip Rose Recreating a WORD Editing Macro to use in Outlook VBA Outlook VBA and Custom Forms 4
M recover deleted items vba macro Outlook VBA and Custom Forms 2
S VBA Macro to VBScript Outlook VBA and Custom Forms 1
B Outlook vba macro Using Outlook 1
B Auto BCC VBA macro: how to add exceptions? Using Outlook 28
D VBA Macro Works in 2007 but errors in 2010 Using Outlook 2
N VBA Procedure (or Macro) to Stop Outlook from Closing? Outlook VBA and Custom Forms 2
M Run external program from Outlook VBA macro Outlook VBA and Custom Forms 5
D New Macro / VBA Outlook VBA and Custom Forms 7
J Specify Font Name or Face using VBA Macro in Word Outlook VBA and Custom Forms 2
S Custom VBA forms in Outlook--how to call w/macro? Outlook VBA and Custom Forms 1
S macro ist just worling wenn vba editor is open! Outlook VBA and Custom Forms 1
S Excel vba code to manage outlook web app Using Outlook 8
