Reply Problem with Outlook.com account
David G
Outlook.com (as MS Exchange)
Hi everyone!
I have a problem with outlook that is driving me nuts! I have 4 accounts currently in outlook, 2 google accounts, one POP3 and an outlook.com account. For some reason, when I add my outlook.com account, whenever I reply to an email in any of my other accounts it sets my outlook.com address as the default reply address. I can manually change it, but I have no idea why it defaults to the outlook.com account. Then when I delete the account off Outlook, the issue disappears, all the accounts use their accounts as the default 'reply' address.
Does anyone have any clue why this happens and how to fix it? I can't seem to see anyone on the web having the same problem which is very frustrating.
Any help would be super appreciated!
David from Melbourne Australia
P Automatic Greeting "Hello Name," when Reply All is clicked Outlook VBA and Custom Forms 1
W Reply to email Using Outlook 4
C UDFs Reply vs Forward Outlook VBA and Custom Forms 3
ThinkToday Calculate reply time of outlook mail Using Outlook 1
J Outlook Reply > From > Other Email Address... > Address Not Showing in Sent Items... From Email Outlook VBA and Custom Forms 0
M Delete headers in Inline reply Outlook VBA and Custom Forms 5
E reply Using Outlook 0
evdbogaard Reply with only last message cited Using Outlook 1
Rupert Dragwater Deleted email address keeps showing up in reply Using Outlook 12
M Reply Inline With a Outlook Template Outlook VBA and Custom Forms 6
J VBA Run When Reply Outlook VBA and Custom Forms 4
D Font in Reply is much larger than normal, how to reset ...? Using Outlook 4
T In-line reply style in Outlook Outlook VBA and Custom Forms 20
Vijay Reply all by attachment name Using Outlook 10
N Lookup Value From Excel and Reply With Matching Value Using Outlook 0
G Outlook 2016: reply icon not showing when replied from mobile Using Outlook 3
J Remove extra line above signature in reply Outlook VBA and Custom Forms 5
C Outlook Attachment List in Reply Header Using Outlook 3
H send reminder if no reply received on first or original email using macro Using Outlook 2
Diane Poremsky Reply to All Includes My Address Using Outlook 0
F Room Mailbox Reply Exchange Server Administration 0
N How to add Dear & mail receipts name while reply to that mail in outlook2007 Outlook VBA and Custom Forms 1
J Force account selection for sending reply emails Using Outlook 1
