Maps/location in making an appointment
Pierce007
Outlook 2016 64 bit
Exchange Server 2013
Several appointment apps for Android has the option to see directly the location of the address where you have an appointment. Can be opened i Google maps.
In Outlook for PC this is not an option as far as I can see. Why and will it be in the future?
Pierce007
Outlook 2016 64 bit
Thanks, will have a go at it this week!
N Free/busy publish at http location does not work Using Outlook 1
L New Location for the Search Bar Using Outlook 6
DoctorJellybean Preserve OST file location in new installation? Using Outlook 4
S Moving .OST file location unsuccessful! Using Outlook 6
W Appointment occurrences change the location property Using Outlook 0
A Missing context menu on Location field Using Outlook 2
Diane Poremsky Meeting Location Warning Message New Slipstick.com Articles 0
Kika Melo Change location of Outlook SecureTemporary Files Folder Using Outlook 5
J Live Meeting Location populate from body Outlook VBA and Custom Forms 4
K After Carbonite restore pst files are found in a weird location Using Outlook 2
I Save selected email message as .msg file (with user to choose folder location) Outlook VBA and Custom Forms 14
Tech Checkers Make Outlook add Contact Card Address in Location Field based on Appointment Subject Name. Using Outlook 2
H Can't change the location of the Data File (.ost) in Outlook 2013 Using Outlook 2
Fozzie Bear Wishlist To be able to add a local folder or network share location in foldern view Outlook Wishlist 1
R Outlook will not send from home location Using Outlook 6
S Workgroup template file location? Using Outlook 2
L Cannot update Location field in Contacts - Runtime Error 438 Using Outlook 0
K Change the default Archive location via GPO in Outlook 2010 Using Outlook 3
P Trying to get 'Calendar Name' to appear like 'Subject' and 'Location' in event Calendar Printing Assistant 0
S Holidays after 2012 & NOT displaying location Using Outlook 8
C Outlook 2010 - Default PST location Using Outlook 4
M Outlook 2003: Restore location Using Outlook 1
Z Mail delivery location - I think Using Outlook 1
T Location and simple copying of emails and settings, OL 2010 and Win 7 64bit. Using Outlook 3
J Remove location field from displaying Calendar Printing Assistant 8
D Junk Mail location Using Outlook 1
D Extracting Location info from All Day Event in mailboxes into webpage Exchange Server Administration 3
J Move PST /changing default location in Outlook 2007 or 2010 64b on W7 64bit Using Outlook 2
G Pop up information location issue Using Outlook 4
C Multiple Locations in Calendar not showing 2nd location in invite Using Outlook 2
J .bcm file location BCM (Business Contact Manager) 1
S New Outlook Distribution List Location Outlook VBA and Custom Forms 2
B Cursor location in email item? Outlook VBA and Custom Forms 2
T Location field Outlook VBA and Custom Forms 1
H popup window "Location Information" Microsoft Office Outlook 2007 Using Outlook 3
V change the Default email Delivery Location Outlook VBA and Custom Forms 3
I Changing Location of BCM data files BCM (Business Contact Manager) 1
F Insert date at cursor location Outlook VBA and Custom Forms 4
D Script help - retain forwarded email body & location of script Outlook VBA and Custom Forms 5
S I have a Question on location of a Custom Outlook menu for my ADDI Outlook VBA and Custom Forms 1
V Making a Date field mandatory in outlook form Outlook VBA and Custom Forms 2
A Outlook 2019 having issues with 'people search' and not making suggestions in email To: etc Using Outlook 12
CWM030 Thinking about making the plunge. Exchange Server Administration 6
