Trial/Beta program for BCM replacement
Microsoft is taking applications to join the beta program for their BCM replacement. You need to be using Outlook 2016 and need to use Office 365 Exchange. (Yes, i know this will leave a lot of people who use BCM out of the program... )
andyga
what do you recommend now to use with Windows 10 and Office 2013/16?
I used Act! before, than I choose BCM because it is free and it is from MS and I could use it with Outlook.
Now they stopped it (like they do with many services - like W10mobile and so on)
So what should I use now?
Should I do my own database with MS Access?
shani
Outlook 2013 64 bit
Can you Please share the link ?
Access is one option. At this time there is not a Microsoft option, unless you have an office 365 exchange online subscription. (And that is still a work in progress).
you need to "apply" using that link and they'll send more information - not sure when or how fast they are expanding the beta. (Will know more next week.)
shani
Outlook 2013 64 bit
Dear Diane ... Thank you for your reponse .. On that link it not even asking for any email address to contact .. One the first page its asking some general questions , no email , or phone number etc .. on second page its says thank you for participating .. can you kindly check yourself .. please fill it up once and see what i am trying to say .. Thanks
do you use office 365 business with an exchange account? that is a requirement (and one reason it's not going to work for a lot of BCM users.)
F My Outlook 2010 Beta Trial ended, I need help getting email and contacts. Using Outlook 5
A How to extend Exchange 2010 Beta Trial beyond 120 days Exchange Server Administration 4
N need to revert back Outlook Express 6, 2010 trial expires tomorrow. Using Outlook 1
C Outlook 2010 Trial Is Up and Now 2007 Address Books Aren't Connecting to Contacts Using Outlook 24
R is import and export engine available in outlook 2010 trial version? Using Outlook 2
D Office 2010 outlook trial Using Outlook 4
G Trial Outlook 2010 Export email and contact Records to Outlook 2003 Using Outlook 1
M What to do after removing trial version of office 2007. Still will not take code Using Outlook 4
B Need help with contact recovery, since trial of Office 2010 has ended. Using Outlook 2
C Installing Outlook 2007 into new computer with Outlook 2010 trial software Using Outlook 2
S Publisher 2010 trial downloads Using Outlook 1
L Keeping Outlook contact, documents and favourites from trial programs installed. cant access these files to export them. Using Outlook 2
K my trial version of outlook 2010 expired and im trying to get my email out of it without deleting th Using Outlook 2
T "Microsoft Outlook has stopped working" error message in Office 2010 Trial Using Outlook 6
W can't export Outlook 2007 mail after trial Using Outlook 2
S Can't get Office trial 2010 to work Using Outlook 3
F trial version of 2010 outlook Using Outlook 1
D OEM Office Professional Trial w/o BCM BCM (Business Contact Manager) 1
A What to do if BCM didn't install with 2007 Professional Trial? BCM (Business Contact Manager) 1
K BCM not downloading with trial software BCM (Business Contact Manager) 1
S Can't install BCM in Ofiice Pro Trial BCM (Business Contact Manager) 4
dbjdbj Is it only me having a fun time with Outlook.com "beta" ? Using Outlook 3
B Beta Testers needed for OutlookTabs Outlook Wishlist 2
D How to uninstall Office 2010 beta if C2R does not work? Using Outlook 0
I Long delay in switching folders since I installed IE 9 Beta Using Outlook 2
R Upgrading to licensed copy from 2010 beta - Outlook won't work Using Outlook 1
D office click-to-run 2010 beta Using Outlook 2
A I can't uninstall Office 2010 Beta! Help please! Using Outlook 1
D What happens to the doccuments when you uninstall the Office 2010 Beta click to Run program in Vista OS? Using Outlook 3
I Activating Expired Beta Using Outlook 1
I Unable to uninstall Microsoft Office 2010 beta Using Outlook 1
B Business Contact Manager 2010 upgrade from Beta - new version does not recognize old version's database Using Outlook 1
S had 2010 beta and need to get to email files and xfer to 2007 Using Outlook 2
S Re: Uninstall Microsoft Office Beta Using Outlook 1
E After 2010 Office Beta expired, my 2007 Outlook version stopped working properly. Can not access correct profile and synchronization with Blackberry p Using Outlook 1
M Uninstall Microsoft Office Beta Using Outlook 1
J outlook 2010 download erase the details from my beta version? Using Outlook 2
S Removal of Beta Test 2010 Office eliminated my 2007 version as well. Huge OneNote files now unavailable. Using Outlook 1
E My Microsoft Office 2010 Beta version has expired. How do I backup my Outlook contacts and email bef Using Outlook 1
G Outlook 2010 Beta has expired Using Outlook 1
J outlook will not open, uploaded new 2010 to replace beta version and everything but outlook works. ____ Using Outlook 4
F outlook 2010 beta email export Using Outlook 7
J Common Feed List - RSS not syncing with IE and desktop RSS gadget (maybe because of IE9 Beta?) Using Outlook 2
S Outlook 2010 Crashes consistently on second reply to an email ... (Release, and not Beta version) Using Outlook 1
W Uninstall MS Office 2010 Beta Professional Using Outlook 2
S Import Messages to Outlook 2007 2010 and 2011 Beta From Entourage 2008 Using Outlook 7
J Outlook 2010 Beta spell check not working Using Outlook 8
J Outlook2010 (beta) is not indexed by Google Desktop Using Outlook 2
T BCM Install fails Both w Off. Pro 2010 Beta & on reinstall Off.Pro BCM (Business Contact Manager) 5
S RE: BCM won't open after installing Office 2010 Beta BCM (Business Contact Manager) 2
