Newbie needs help with Outlook Macro
chrisk2305
Outlook 2016 64 bit
Hi Guys,
My Goal is create a Outlook Macro that adds the date into the subject line of every email for the following occasions:
Every email that arrives
Every new Email I create
Every Email I answer or forward
The Subject should look like: "2016-05-11 This is a test"
My first try was to create a script rule for incoming emails. The script contains the following code:
Sub ChangeSubject()
Dim myolApp As Outlook.Application
Dim aItem As Object
Set myolApp = CreateObject("Outlook.Application")
Set mail = myolApp.ActiveExplorer.CurrentFolder
For Each aItem In mail.Items
      aItem.Subject = "Date" & aItem.Subject
    aItem.Save
Next aItem
The code was actually copied from this side. But actually nothing happens and I have no idea how to debug. Can you guys help a noob? :)
Thanks in advance!
Christian
It works on the selected folder, but is not what you want - it adds Date to the subject line:
DateOutlook Tip for May 9 2016
I'm assuming you want something more like this;
5/11/2016 Outlook Tip for May 9
which is set by this:
aItem.Subject = Date & " " & aItem.Subject
Date = today's date - if you want the received date:
2016-05-09 Outlook Tip for May 9 2016
use
aItem.Subject = Format(aItem.ReceivedTime, "yyyy-mm-dd") & " " & aItem.Subject
But... this macro is one you need to manually run. If you do that, you need to check the messages to see if the date was already added, otherwise, you'll add it to every message in the folder.
If you want it done automatically, you need an itemadd macro.
How to use an ItemAdd Macro
There is an itemsend mail here - Add a keyword to the subject of all messages sent - that can be tweaked to add the date.
chrisk2305
Outlook 2016 64 bit
alright, got everthing working so far. But i have one question: How is it possible to answer an email that already has the date in the subject and replace it with date of answering event and also to replace an exisiting date upon receiving with the current date. I hope I could make clear what I want to achieve. Thanks in advance!
J Newbie needs help Outlook VBA and Custom Forms 2
J Newbie confusion Using Outlook 0
E Newbie, desperately seeking help Using Outlook 2
S Seperating email accounts, Syncronizing, and a few newbie questions Using Outlook 5
C Newbie import issues Using Outlook 3
A General, how to get started? [kwrds begin start newbie] Outlook VBA and Custom Forms 3
R Newbie get_CurrentItem() question Outlook VBA and Custom Forms 6
Y Newbie : What is http://schemas.microsoft.com all about? Outlook VBA and Custom Forms 2
lotsbg Loads of junk in second email needs fixing Using Outlook 1
R Narcotics Police Officer Needs help Using Outlook 1
Y Changing colour of selection bar in Outlook (too light, needs to be grey) Using Outlook 4
J To-do bar needs to show appointments from multiple calendars Outlook Wishlist 3
C Beginner Needs VBA Help in Modifying Code Outlook VBA and Custom Forms 2
Forum Admin What needs fixing in Outlook? Outlook Wishlist 18
B HELP! Using Outlook 4
