Custom form not showing when recurrence is set for a meeting
abhijeet
Outlook 2013 32 bit
I am using custom appointment form to setup meetings. This works fine in normal scenario.
When I set up a recurrence meeting using the custom form and if I try to edit entire series it shows the custom form. But when I try to edit one of the instance of the meeting from the series then it does not show custom form.
Please help.
A Updated custom form not showing with old items Outlook VBA and Custom Forms 2
R Custom Contact Form how to update when loaded. Outlook VBA and Custom Forms 6
S Custom form with dropdown Using Outlook 0
P Custom form reverts from task Outlook VBA and Custom Forms 1
L Outlook Custom Form Using Outlook 2
Diane Poremsky The custom form cannot be opened. Outlook will use an Outlook form instead. Using Outlook 0
