Insert Hyperlinks for attachments in Userform
B Caspe
I would like use VBA to insert Hyperlinks for mail item attachments into an Outlook userform.
Mail items would be handled one at a time and the code would be run by a command button on the (inspector) ribbon of opened mail items. This would save all the item's attachments to the hard drive and then insert hyperlinks to these file locations into a userform -- either into a label or a textbox.
I've found some good ideas online but all are for Excel userforms / use excel functions. For example: Excel Tips From John Walkenbach: Adding A Hyperlink To A Userform
Any suggestions on accomplishing this on an Outlook userform?
If not, maybe an excel form or functionality can somehow be used?
Thanks for any suggestions
If you wanted to use a pretty link you can put the url in the ControlTipText or Tag property of the control and change the code to use that property - or just put the url in the code
objWeb.Navigate "http // the url goes here"
B Caspe
Thank you for the quick and interesting response Diane, I will start working with it.
The examples you give use internet explorer and link to the web, what I want to do is use hyperlinks to open files on the hard drive. Could this also be accomplished?
B Caspe
Thinking about this ... if the labels can be programmed to populate with the file paths of the saved attachments, then maybe the label click event could call a File System Object sub (etc) that would open the file?
witzker Outlook 2010 Insert Date & Time at the button of an OL contactform in red Using Outlook 2
L Automatically Insert Recipient Name from To Field Outlook VBA and Custom Forms 33
Diane Poremsky Create Task or Appointment and Insert Selected Text New Slipstick.com Articles 0
D Outlook task insert Outlook VBA and Custom Forms 3
K Insert screenshots issue Using Outlook 2
makinmyway Recent Files Not Updating when Using Insert Hyperlink in Outlook 2013 Using Outlook 0
L Insert Photo to Contact Using Outlook 23
K OL2010 Button to Insert First Name Outlook VBA and Custom Forms 6
K OL2010 Button to Insert First Name Using Outlook 1
witzker insert Date & Time (HH:mm) no (ss) in userform Using Outlook 6
A insert Date & Time in userform Using Outlook 3
K Macro to insert attachments Using Outlook 1
C Insert a Date Picker for Send Mail Subject Using Outlook 1
C Insert date in Subject through date picker Using Outlook 0
mrje1 Opening a task the Insert Tab Option is not showing up and organizing Tasks Using Outlook 9
H Insert Specific Text before Subject for New mails and reply Using Outlook 3
R insert picture tab grey Using Outlook 1
K Outlook insert clip art, no results found...address book contacts only show up Using Outlook 5
J Form design - how do I insert an automatic date/time field? Using Outlook 2
J How do I view the ruler in an Outlook message and/or insert tabs? Using Outlook 7
L Forward Email and Insert Sender's Email address in body Outlook VBA and Custom Forms 3
D Insert Text and Send Outlook VBA and Custom Forms 1
D Re: How do i insert radio buttons in an email Outlook VBA and Custom Forms 1
G How to insert a json array into a calendar events Outlook VBA and Custom Forms 1
K insert text into current position of pointer in mailcompose Outlook VBA and Custom Forms 1
J Insert File Outlook VBA and Custom Forms 2
M Insert a File Outlook VBA and Custom Forms 3
G Task / Insert / Attach Item / Business Contact BCM (Business Contact Manager) 1
M Forward email as insert from button Outlook VBA and Custom Forms 1
B Simple way to insert file text - macro? Outlook VBA and Custom Forms 1
S How to insert a picture programatically Outlook VBA and Custom Forms 12
C insert a picture Outlook VBA and Custom Forms 1
J How do I scan and insert into Outlook 2007? Using Outlook 3
B Insert information to MailItem Outlook VBA and Custom Forms 1
D RE: How do you change the default insert file path in outlook? Using Outlook 11
D Insert Text via Macro in Outlook 2007 Outlook VBA and Custom Forms 2
T Is it possible to INSERT a string into email body via Shortcut. Outlook VBA and Custom Forms 2
J Command Button to insert Email Signature Outlook VBA and Custom Forms 2
D Macro creation for Outlook insert subject Outlook VBA and Custom Forms 1
F Insert date at cursor location Outlook VBA and Custom Forms 4
T Insert text from file Outlook VBA and Custom Forms 1
S How to create a macro to insert a signature in Outlook 2007 Outlook VBA and Custom Forms 1
T How do i insert a page break in an Outlook e-mail message? Using Outlook 4
