changing FW: on forward
rinu
Outlook 2013 64 bit
Hi All,
I am new to VBA so any help will be greatly appreciated . I have to forward a mail from specific subject but need to get rid of FW: from the subject along with the signature and old users subject, emails...etc.
how do i do it ?
Regards
Roma
i have samples here Run a Script Rule: Change Subject then Forward Message
changing the subject and removing the forward header and your signature is a piece of cake, removing the original sender's signature is more difficult, especially if they don't use a signature separator - you need to know where to split it.
rinu
Outlook 2013 64 bit
I was able to get it work with the below code. But it seems to be messing up the formating. After running the below code all the Rich text content seems to be missing from the body.
Sub RemoveExpression()
Dim Insp As Inspector
Dim obj As Object
Dim subStr As String
Dim oMail As MailItem
Dim itmOld As MailItem, itmNew As MailItem
Set Insp = Application.ActiveInspector
Set oMail = Insp.CurrentItem
lPosition = InStr(oMail.Body, "Subject: ") - 1
' obj.Subject = Mid(oMail.Subject, 5)
subStr = Left(oMail.Body, lPosition)
oMail.Body = Replace(oMail.Body, subStr, "")
oMail.Subject = Replace(oMail.Subject, "FW:", "")
'obj.Body = Replace(obj.HTMLBody, "abc", "")
Set obj = Nothing
Set Insp = Nothing
rinu
Outlook 2013 64 bit
I did it with the below code
lPosition = InStr(oMail.HTMLBody, "Subject:") + 7 + (Len(oMail.Subject)) + 1
subStr = Left(oMail.HTMLBody, lPosition)
oMail.HTMLBody = Replace(oMail.HTMLBody, subStr, "")
Set obj = Nothing
Set Insp = Nothing
Gary Hile Outlook 2016 changing editor options Using Outlook 6
T Changing default Mail Account in Outlook 2016 - POP3 Using Outlook 1
Stephen Weinberg Changing the mailing address checkbox Using Outlook 0
C Changing the name of Outlook Messages saved to a folder Using Outlook 1
A Outlook.com changing appointments Using Outlook 8
B Changing CC list to .add Outlook VBA and Custom Forms 2
Diane Poremsky Changing the Message Size in Exchange Server New Slipstick.com Articles 0
Diane Poremsky Changing the default *.pst and *.ost sizes New Slipstick.com Articles 0
P Message Class keeps changing back to IPM.Contact Outlook VBA and Custom Forms 2
Diane Poremsky Changing Outlook.com color schemes New Slipstick.com Articles 0
L Office 365 Outlook changing default contact folder Using Outlook 0
Diane Poremsky Changing the From Domain in Office 365 New Slipstick.com Articles 0
R The changing way to access information in Office 365 New Slipstick.com Articles 0
William Yeack Outlook/Exchange - Changing display of “From” user Using Outlook 3
divan VbaProject: Changing email format Using Outlook 15
C Changing Domain -- Assigned To User field Migration? BCM (Business Contact Manager) 1
M CHANGING ACCOUNT NAME Using Outlook 0
J Changing margins in received email display Using Outlook 3
B Automatic picture download and changing email addresses Using Outlook 3
L changing view settings based on message body Using Outlook 1
M How to automatically refresh an appointment windows after changing the MessageClass property ? Outlook VBA and Custom Forms 4
J Changing Contact Notes Font Outlook VBA and Custom Forms 9
cimbian Changing default contact view Using Outlook 2
S Outlook custom checkbox not changing value Using Outlook 0
E Changing layout of forms in BCM Using Outlook 1
P Changing from POP to IMAP; will this setup work? Using Outlook 1
V View zoom setting changing Using Outlook 1
B New hosting server & changing IMAP accounts Using Outlook 2
S Auto Complete incorrect after changing an email address Using Outlook 3
