Autosave attachments error using Len
scooby99
Exchange Server 2007
Im trying to autosave attachments with the subject. However, the subject is quite long and the first 33 characters are always the same, while the remaining part can differ in length. Ive been looking at some code and modified it as follows using the Len statement but i cant get it to work. Instead I get error messages that the path doesnt exist. Anyone has any ideas what im doing wrong?
Public Sub test(itm As Outlook.MailItem)
Dim objAtt As Outlook.Attachment
Dim saveFolder As String
Dim fDate As String
Dim posr As Integer
If Weekday(Date) = vbMonday Then
fDate = Format(Date - 3, "YYYY-MM-DD")
fDate = Format(Date - 1, "YYYY-MM-DD")
saveFolder = "C:\Tickets\" & fDate & "\"
For Each objAtt In itm.Attachments
objAtt.SaveAsFile saveFolder & "\" & Mid(itm.Subject, 33, len(itm.Subject)- 32) & ".pdf"
Set objAtt = Nothing
scooby99
It seems that the problem lies with the fact that theres a "/" in the subject.
If I remove it from the subject, the code works fine. Does anyone know how I can modify the code to handle the issue with "/"?
scooby99
I solved it myself by adding a replace argument into the code :)
M How to AutoSave Attachments that meet a criteria to a folder on a local drive Outlook VBA and Custom Forms 3
D Autosave Attachment and Rename Outlook VBA and Custom Forms 1
C appending 'Date Modified' to autosave script Outlook VBA and Custom Forms 19
C Outlook 2007 Autosave feature and Draft folder Using Outlook 2
J Outlook 2010 messages freeze in outbox, do not autosave, then disappear after Outlook locks up Using Outlook 7
A Attachments.Delete Outlook VBA and Custom Forms 3
shrydvd vba to secure zip attachments Outlook VBA and Custom Forms 3
R fetching blocked attachments Outlook VBA and Custom Forms 0
H Outlook 2016 sent over 30 copies of an e-mail with attachments Using Outlook 1
R Outlook is NOT removing attachments. Using Outlook 4
Dan_W Nested email attachments Outlook VBA and Custom Forms 4
S DRAGGING MAIL AND ATTACHMENTS TO CALENDAR Using Outlook 1
G Download pdf attachments only if email subject has one of words Outlook VBA and Custom Forms 8
O Wishlist Native solution to detach attachments but keep a link to them Outlook Wishlist 1
I Forwarding attachments in email received Outlook VBA and Custom Forms 3
M Outlook 2016 msg attachments Using Outlook 0
M Macro for attachments download adjustment Outlook VBA and Custom Forms 3
Diane Poremsky Save Messages and Attachments to a New Folder New Slipstick.com Articles 0
B Delete/replace old files and save new attachments Using Outlook 1
Diane Poremsky Disable Protected View for Outlook Attachments New Slipstick.com Articles 0
C Saving Outlook attachments and links to attachments with VBA Outlook VBA and Custom Forms 2
Diane Poremsky Remove Attachments From Messages New Slipstick.com Articles 0
Diane Poremsky Outlook is sending winmail.dat attachments New Slipstick.com Articles 0
Diane Poremsky Edit and Save Outlook's Read-Only Attachments New Slipstick.com Articles 0
J Forward Message after editing attachments and include edited attachments Using Outlook 5
Diane Poremsky Save Attachments to the Hard Drive New Slipstick.com Articles 2
