Outlook problems
Gary Berg
Outlook 2013 32 bit
I've got a couple of symptoms here. Office 365 running the 2013 versions.
1) When I create an email and place it in the outbox it often switches immediately from an envelope symbol to the open letter symbol. Sometimes if I copy/paste the contents to a fresh email I can send it. Opening one of these emails and pressing send results in the same flip/flop again.
2) I figured I had PST problems and tried to run Scanpst. The process runs, stays stuck in ram for a while, and then the process disappears. I never get a dialog box.
Any suggestions as to where to look? Should I update to the Office 2016 that's available, or while I just carry trouble over?
Windows 7, Bitdefender AV 2015
1. Something - usually an AV scanner, some versions of OneNote integration is also known to do it - is 'reading' the outgoing mail when you look in the outbox. Stop looking in the Outbox or stop using that software. :) If Bitdefender installs an outlook addin, that is the likely cause - stop using the addin, it's not necessary and adds little value anyway.
After viewing the Outbox, messages won't send
2. How big is the pst? Any errors in the event viewer?
Gary Berg
Outlook 2013 32 bit
The PST file is only a couple hundred Mb in size; I move email after I read it to a different PST. I have 8-9 PST files attached in Outlook. Total aggregate size is maybe 2Gb. This has worked fine for years. As for event log, the only thing I see is warnings on 2 PST files about detecting a catalog checkpoint. It could have been doing this for years.
I will search Outlook add-in again. The add-in section in Outlook options lists Evernote clipper, Evernote contact connector, gsyncit, MS Exchange, and TechHit Simplyfile. Others are listed but disabled, including OneNote Notes.
V Outlook 2016 Outlook-2016 and iCloud for Windows - Problems Using Outlook 10
P outlook.com problems Using Outlook 0
D Outlook and Icloud problems Using Outlook 0
E Outlook 2010 network printing problems Using Outlook 4
P Encoding problems after synchronization with Outlook Connector Using Outlook.com accounts in Outlook 6
J problems with viewing aol emails in Outlook Using Outlook 3
B Problems with outlook calendar and android phone syncing calendars Using Outlook.com accounts in Outlook 1
P Sync Problems Outlook with iPad 2 Using Outlook 3
C migrating from Windows Live Mail over to Outlook 2010 Problems ... Using Outlook 2
J Outlook 2010 and Icloud multiple calenders problems. Using Outlook 10
T Outlook 2007 - iTunes - iCloud Sync Problems Using Outlook 7
S Public FolderEmail Sort Problems Outlook 2010/Migration from 2003 SBS to 2011S Using Outlook 3
S Outlook 2010 and certificate problems Using Outlook 9
M Several Problems using Outlook Using Outlook 3
W Outlook exp. 2007 problems - won't receive new mail Using Outlook 1
P Printing problems with MS Outlook 2000 Using Outlook 1
A Two strange calender problems in Outlook 2003 ... Using Outlook 2
T Outlook 2007 shut down problems Using Outlook 1
A Outlook Advanced Search Problems...returns with an Error: Argument Outlook VBA and Custom Forms 1
J Problems with Outlook.Recipient.Resolve Outlook VBA and Custom Forms 3
T Problems re-installing BCM for Outlook 2007 BCM (Business Contact Manager) 2
F Wishlist Outlook suddenly began synchronizing deleted items every time I delete a single email. Using Outlook 1
K Outlook 2019 Randomly Disconnecting from Gmail Servers Using Outlook 6
