Janus Orr
Outlook 2013 64 bit
Hello All!
This is the first time I'm posting a question here; I have searched and searched and searched here and other places and I cannot seem to get any results. I'm using VISUAL BASIC 2015 in Visual Studio 2015.
QUESTION: I need to have a modal window/popup from a particular website remain INSIDE the web browser control/window on my form (WebBrowser1); when a particular link is clicked, the modal window/popup jumps out of the form and directly to the user on their screen. I have to keep this popup inside because there are other links to be clicked inside that popup, but if it jumps out of the web browser control, no code will work since it's outside WebBrowser1.
What I have found is code for older versions, and not 2015; if anything I can even add WebBrowser2 to have the popups/modal windows appear there if possible, just as long as I can code them to keep clicking inside the form.
PLEASE HELP! THANK YOU!
M Anyone with this Microsoft Outlook issue can help? Using Outlook 1
A from Arthur to anyone I need your expertise assistance Using Outlook.com accounts in Outlook 7
O Importing Mbox - anyone out there having experience with this tool... Using Outlook 3
V Anyone Using CodeTwo Sync for iCloud ? Using Outlook 28
S Anyone know how to transfer Outlook Express "Identities" to Outlook 2010 ... Using Outlook 1
C Anyone found a way to customize search? BCM (Business Contact Manager) 5
D Does anyone understand Outlook 2010??? Using Outlook 1
J Does anyone know if there is a theoretical limit to the number of personal folders permitted within Using Outlook 2
G Anyone had problems using OLF.Items.Count with Outlook 2010? Using Outlook 1
S My Outlook Filing Cabinet has disappeared! Does anyone know how I get it back?? Using Outlook 1
A Need to upload Pic in Microsoft Outlook... Can anyone suggest How? Using Outlook 1
K Does anyone know how to turn off auto capitalization in Outlook 2007 running on Windows 7? Using Outlook 6
S CAS Load Balancing with Cisco IOS SLB - anyone done it? Exchange Server Administration 2
D Mailbox permissions (Send As) - Anyone can send as anyone... Exchange Server Administration 7
M Has anyone had problems with Iphone back-up? Could this damage registry? Using Outlook 1
J Does anyone know if OWA 2010 has an "Autosave" feature? Using Outlook 1
B I´m trying to export an outlook folder to a USB device. Does anyone knows how to do it? Using Outlook 1
K I can't delete messages and it states that someone is using my delete. Does anyone have any possible solutions. Using Outlook 2
C Does anyone know how to get into the Offfice 2010 email Account Settings. Using Outlook 1
R Anyone have a sample macro for Outlook 2007 (setting the zoom)? Outlook VBA and Custom Forms 1
B HELP! Using Outlook 4
M Winmail. dat - HELP Using Outlook 2
