Avoid sending duplicate using Outlook script
Frederick Hung
Outlook 2013 64 bit
Exchange Server 2013
Hi Diane, I have written an Outlook script to process incoming emails that meets the Outlook rules. The script will reformat the subject (based on the attachment), modify the body and then fwd the email to specified recipients.
It's been working well until recently we face a challenge, the same email may come from 2 different senders, and my script will process them individually which means it will Output to recipient twice. Is there any way to stop the script from processing duplicate?
One thing I can think of is to check the attachment name which is saved. Below is my current script, how can I enhance it to check for duplicate? Appreciated your help in advance.
Sub SendNew_Attach(Item As Outlook.MailItem)
Dim objMsg As MailItem
If Item.Attachments.Count > 0 Then
Dim attCount As Long
Dim strFile As String
Dim sFileType As String
Dim strFolderpath As String
Dim objAttachments As Outlook.Attachments
Set objAttachments = objMsg.Attachments
attCount = Item.Attachments.Count
For i = attCount To 1 Step -1
strFile = Item.Attachments.Item(i).FileName
sFileType = LCase$(Right$(strFile, 4))
Select Case sFileType
Case "xlsx"
' do something if the file types are found
' this code fwd the attachment and change the email subejct n body
strFolderpath = CreateObject("WScript.Shell").SpecialFolders(16)
strFolderpath = strFolderpath & "\OLAttachments\"
strFile = strFolderpath & strFile
' Save the attachment as a file.
Item.Attachments.Item(i).SaveAsFile strFile
Next i
Should be able to use DIR instead - that would avoid using the filesystemobject (not that it's a big deal, but i like small and compact. :)
If Dir(strFile) <> "" Then
exit sub
end if
C How to avoid sending mail to the wrong contact person New Slipstick.com Articles 1
R How to configure outlook to avoid sending emails from the wrong account Using Outlook 24
R How to avoid reminders from delegators' Calendars? Using Outlook 1
C How to avoid an Outlook message that pops up Outlook VBA and Custom Forms 1
R Hi, Ken, What should be noticed to avoid memory leak in outlook addin? Outlook VBA and Custom Forms 3
V Form data not sending for some users Outlook VBA and Custom Forms 2
R Microsoft Outlook 2016 - Gmail not sending, asks for password for SMTP, tried different ports Using Outlook 23
A Flag Message for Follow Up after sending Outlook VBA and Custom Forms 1
D Sending email from Office 365 alias in Outlook Using Outlook 3
E Change sending account depending on Subjectline Outlook VBA and Custom Forms 0
R Warn before sending message Outlook VBA and Custom Forms 4
HarvMan Hotmail - Sending email is undeliverable Using Outlook 4
A Sending contact vcards sends older version instead of updated version Using Outlook 4
M McAllister Outlook stops Sending/Receiving/Synching after disconnecting remote desktop session Using Outlook 2
B When sending an email, I am showing 2 of my address's Using Outlook 1
A Check for words in subject header before sending email Outlook VBA and Custom Forms 4
W Sending To Wrong Account Using Outlook 15
H Select Specific Account When Sending Email, Based on Current Folder Outlook VBA and Custom Forms 1
M MsgBox when not sending from specified account Outlook VBA and Custom Forms 2
R Sending emails via Outlook XP, from Windows 10 File Explorer Using Outlook 1
L Creating drafts when I thought I was sending Using Outlook 1
C address book "when sending email" bug? Using Outlook 0
H Custom autoforwarding, sending mail through outlook office 365 Using Outlook 1
C replace subject line generated by converting a word document to PDF and sending it to an email Using Outlook 8
A Sending Emails Through Outlook From Multiple Email Addresses Using Outlook 1
P Outlook 365 sending intermittently Using Outlook 0
V iCloud Calendar invitations not sending Using Outlook 3
O Rules and Alerts for New Messages BEFORE sending Using Outlook 2
latitudeit Outlook for Android - Sending from an alias address Using Outlook 2
A How to get rid of "sending on behalf of" when sending from Outlook 2016 client Using Outlook 12
Diane Poremsky Automatically create a task when sending a message New Slipstick.com Articles 0
P Categorise emails on sending - macro not working in Preview mode Using Outlook 1
Diane Poremsky Outlook is sending winmail.dat attachments New Slipstick.com Articles 0
Diane Poremsky Select from a List of Subjects before Sending a Message New Slipstick.com Articles 0
Diane Poremsky To delay sending a message in Outlook New Slipstick.com Articles 0
D Close Oulook after sending emails via vba without outbox getting stuck. Outlook VBA and Custom Forms 1
M godaddy says my outlook's sending spam. Using Outlook 4
