scanpst.exe will not open
coastalcraig
Outlook 2013 64 bit
I have an upgraded Windows 10 computer and I am running Microsoft Office 2013 (click to run I believe). It has been easy for me to locate the scanpst.exe file. It is located at: C:\Program Files (x86)\Microsoft Office\root\Office16\scanpst.exe
I have read high and low and have seen a couple of people mention that the scanpstXX.dll file was not in the same folder but mine is:
When I double click on scanpst.exe nothing happens at all. If I right click and choose "Run as administrator" a User Account Control window will pop up and ask if I want to allow the program to make changes to my computer. When I click on the "Yes" button the User Account Control window disappears and the program never opens.
Does anybody know what I should do to get scanpst.exe to run on my computer?
Z Outlook 2010 will not open - scanpst.exe. worked once now get to 'Loading Profile' and stays there (win 7) Using Outlook 1
G Outlook won't open and received the scanpst.exe error. Using Outlook 2
J I cannot open outlook. It says errors have been detected in the file. It says to run scanpst.exe but__I cannot find it on the computer. Can I get help Using Outlook 1
O When I try to open Outlook, I get a message saying the program is corrupted and it directs me to use scanpst.exe. However, I can't run the scan, becau Using Outlook 1
J deleted some files infected with virus as advised by scan tool, but now cannot open outlook. Cannot locate scanpst.exe on my Vista based computer Using Outlook 2
B help!!!! cannot run outlook1.pst. errors, then something about (scanpst.exe) help?? will not open ou Using Outlook 2
C scanpst.exe doesn't repair .pst file Using Outlook 1
makinmyway ScanPST.exe Missing Repair Button Using Outlook 15
G Error when running scanpst.exe Using Outlook 1
H ran scanpst.exe and that fixed most, but cannot access personal folders Using Outlook 1
S CSCANPST To Automate Running SCANPST.EXE Using Outlook 1
U How do rename a recovered folder after repairing using scanpst.exe Using Outlook 1
B Trying to find & run Scanpst.exe. Outlook can't log onto server. Have removed update KB2412171 & it did not correct problem. Have done a resto Using Outlook 2
S Error in outlook.ost file, scanpst.exe does not work. Using Outlook 4
S missing scanpst.exe file Using Outlook 6
E Re: Can't locate scanpst.exe file Using Outlook 1
G Scanpst.exe error but can't find file that needs to be fixed due to outlook not opening up Using Outlook 3
R Problem with scanpst.exe Using Outlook 1
G Scanpst.exe on windows 7 Using Outlook 1
N Inbox repair tool - scanpst.exe. That file is missing from my computer. Using Outlook 2
E Scanpst.exe tool cannot be found Using Outlook 1
J can't find scanpst.exe to fix email problem Using Outlook 2
E Scanpst.exe Using Outlook 2
T Outlook 07 - Vista - Error 0x80040600 - Cannot find scanpst.exe - Looked everywhere Using Outlook 1
D Scanpst.exe Using Outlook 2
H Office OUtlook 2007 gives error message that says to run scanpst.exe and this is not found on my com Using Outlook 3
R Can't find scanpst.exe anywhere on my PC - Office Pro 2010. How can I repair a corrupt PST file? Using Outlook 2
A Outlook 2007 errors have been detected. Can't locate the personal file I need run the scanpst.exe on so the repair can take place. Using Outlook 3
H Scanpst.exe Using Outlook 1
M Re: Can't locate scanpst.exe file Using Outlook 1
J inbox repair tool (scanpst.exe) for windows vista Using Outlook 2
J scanpst.exe Using Outlook 1
J Scanpst.exe is missing from my Program Files. Using Outlook 1
C Error Code 0x80040600, Tried the SCANPST.exe but did not work. Still cannot receive email. Need an Using Outlook 1
C Re: Error Code 0x80040600, Tried the SCANPST.exe but did not work. Still cannot receive email. Nee Using Outlook 2
J scanpst.exe freeze at phase 7 Using Outlook 1
R scanpst.exe has lost some recent data. Using Outlook 7
R PST and scanpst.exe finding folders Using Outlook 1
D if scanpst.exe doesn't fix it? Using Outlook 11
O SCANPST.EXE OUTLOOK FAILURE Using Outlook 1
C Can't find scanpst.exe after unhiding files. Using Outlook 2
F What should I do when ScanPst.exe does not repair my outlook.pst? Using Outlook 2
Y Scanpst.exe Where can I download this file it is missing and I cannot access Outlook Using Outlook 5
P Outlook is over size limit; scanpst.exe doesn't work; can't delete anything. Using Outlook 3
A Outlook 2007 & error 0x80040600 & missing scanpst.exe Using Outlook 3
J scanpst.exe not found in windows 7 64bit Using Outlook 12
B Outlook fails - error says execute scanpst.exe but can't find it Using Outlook 8
P errors appear every time I run SCANPST Using Outlook 3
A ScanPST finding errors but no Repair button Using Outlook 2
Diane Poremsky Using Scanpst in Outlook Click to Run New Slipstick.com Articles 0
