Adding textbox filter to listbox?
framednlv
Outlook 2016 64 bit
I have a listbox using the code form Outlook VBA: Use a Text File to Populate a ListBox . It populates the listbox with job numbers for saving emails to the server. I would like to add a text box to enter a keyword to filter the listbox. The only examples I can find are for excel, such as this one here.
Does anyone know/have a code example for adding a filter to the listbox in Outlook?
Chris
I don't have any examples, but the same general method should work in Outlook. you can download the workbook sample, export the userform and then you just need to cleanup the code to use your data source (that's the hard part :)).
framednlv
Outlook 2016 64 bit
I really would like to do this, so perhaps one step at a time.
How can I add a second column to the listbox, current code for the list box (thank you Diane):
Private Sub UserForm_Initialize()
  Dim fn As String, ff As Integer, txt As String
    fn = "H:\Software\OutlookVBA\project_list.txt" '< --- .txt file path
    txt = Space(FileLen(fn))
    ff = FreeFile
    Open fn For Binary As #ff
    Get #ff, , txt
    Close #ff
Dim myArray() As String
  'Use Split function to return a zero based one dimensional array.
  myArray = Split(txt, vbCrLf)'I'm guessing it would need to be modified here?
  'Use .List method to populate listbox.
  ListBox2016.List = myArray
lbl_Exit:
G Removing old emails when adding accounts Using Outlook 3
D Contact Group - Adding Bulk Addresses Using Outlook 2
E Project Management - Adding Folders for Different Folder Types Using Outlook.com accounts in Outlook 0
O Adding a new account - "CompanyL (none)" line is added Using Outlook 5
W Adding A Macro To Message Ribbon Outlook VBA and Custom Forms 2
I Collecting mail address from GAB and adding to Outlook Task Using Outlook 2
A Outlook 2016 - adding outlook.com account creates a new/strange address Using Outlook.com accounts in Outlook 18
J Adding Reply & Delete to main toolbar? Using Outlook 0
T Outlook 2007 adding categories Using Outlook 15
Diane Poremsky Adding Emojis to Outlook's AutoCorrect Using Outlook 0
T Adding "Mark As Complete" btton to Task Remindet Pop-Up Using Outlook 3
Ascar_CT Adding contacts on Android phone and then syncing them to Outlook Using Outlook.com accounts in Outlook 4
A Adding a 2010 sharepoint contact list to outlook 2010 address book Using Outlook 1
M Adding fields to Task in Outlook Home and Business 2010 Outlook VBA and Custom Forms 7
S Using Send on Behalf is adding extra data in from line Using Outlook 1
Lucylou Outlook 2013 Adding Outlook.com breaks profile, "Outlook not working" messag Using Outlook.com accounts in Outlook 1
C Adding Categories when Composing Email Using Outlook 1
stephenjones Adding a business account to Outlook Using Outlook 1
Chris Grew Adding 2nd Email Address BCM (Business Contact Manager) 3
G Adding an attachment to email I just created (VBA) Outlook VBA and Custom Forms 1
L Adding sender's e-mail to global address book DL Outlook VBA and Custom Forms 1
R Adding vba to script list Outlook VBA and Custom Forms 4
F Adding User Defined Field to another form Using Outlook 0
Edaniels Adding Week Number on Calender Using Outlook 2
I Adding appointments/tasks to other user's calendar Using Outlook 1
