Odd Folder View Problem
PetraTech
Outlook 2013 64 bit
I'm running Outlook 2013 as an IMAP on Windows 10 and using iCloud.
I was having a problem with the iCloud add-in not loading and so I uninstalled iCloud and reinstalled. Then I lost my Contacts (this computer only) and Calendar (this computer only). Normally when I save a contact, I just moved it to my iCloud contacts. Then when I was saving meetings, I couldn't find them.
Finally I found my missing Contacts, Calendar, and Tasks under the Trash Folder. The only way that I can see these folders is when I click on the IMAP account, then in the Outlook Today, I have to click on Calendar. Then it opens up all the folders (with different icons) and I can see the missing folders under Trash.
However, when I click on the Mail link on the bottom left of the screen, it changes view and I can't see the missing folders.
What's really odd is that the file properties all point to the same location.
This is a screenshot of the default folders:
This is a screenshot of the view I would like to have and the deleted folders:
Any help would be greatly appreciated.
Thanks so much, Robert
iCloud now moves those folders to trash when the IMAP account is set up as the default and you sign in to iCloud.
When you click the mail link, you only see Mail folders. If you want to see all folders, you need to use the Folder list view - Ctrl+6 will open it or the folder name or icon at the bottom of the navigation pane. Click the 3 dots if you don't see the folder icon.
i think icloud does it to reduce confusion - this removes them from the Calendar pane.
V Calendar event acting odd Using Outlook 7
C Odd error message not found in Google search Using Outlook 1
R Outlook 2013 - Odd Sync behaviour Using Outlook 1
V Odd data file? Using Outlook 5
D This is odd Using Outlook 2
O How do I get rid of odd formatting of new e-mails? Using Outlook 3
U Odd behaviour for auto-receive Using Outlook 2
C Open message is stuck minimized -Odd behavior when replying to a message(2010) Using Outlook 1
H Odd symbol when stripping characters using vba Outlook VBA and Custom Forms 3
P Posts in Folder No Longer Group by Conversation Column After Search Using Outlook 0
Horsepower Moving emails between folder Outlook for Mac Outlook Wishlist 8
D How to remove a folder, option grayed out Using Outlook 4
D How To Combine Share Task Folders in just one Folder Using Outlook 0
G Retention Policy for Outlook.com Deleted Items folder Using Outlook 0
M Move to Folder Using Outlook 1
K Export Folder to PST Outlook VBA and Custom Forms 2
B Spam folder not showing in Outlook Using Outlook 5
J Moving Imported folder Using Outlook 2
B VBA to Collapse Task Folder Groups Outlook VBA and Custom Forms 1
D Outlook 2016 Deleting emails without affecting folder structure - Outlook Office 365 Using Outlook 3
B Outlook 365 - Folder pane list clears Using Outlook 28
R Folder pane width change Using Outlook 62
T Missing Folder in Outlook.com Using Outlook 3
N Outlook 2016 Folder Icons Look Using Outlook 0
