VBA Help Email that will save as draft and send as attachment
BlackOps
Exchange Server 2010
Hi people. Would need some help with vba in outlook.
Currently i have a macro that detect emails send to external and will do a prompt that ask if the email is checked. Would want to work on having the vba script to check on the email sent and in a prompt, ask the user if he want to send it as an attachment for his supervisor to check, if yes, the email will be save as draft and forwarded out, else the email will not be sent.
Best case would be if the script can detect if there is an attachment, if yes, ask if he would like to forward to his supervisor to check, if not, no action taken. Also if there is no attachment, it will check if this email is send to external, if yes, does a prompt if email check, if yes proceed to send.
You'd start with the macro at Check for missing attachments before sending a message - it shows how to check for attachments. (Remove the first If and last End if, change .count = 0 to .count > 0)
Do something like this in the cancel line (that should send as forward, not forward a draft tho - will need to create a new item and attach the draft) -
If answer = vbNo Then Cancel = True
fw = item.forward
fw.to = "boss@domain.com"
fw.send
This works... but the recipient needs to use Resend Message to send it (at least my test recipient did.) It's in the sent folder as a draft attached to the message.
        If Item.Attachments.Count > 0 Then
          answer = MsgBox("Do you want to send this for approval?", vbYesNo)
          If answer = vbYes Then Cancel = True
          Item.Save
          Set fw = Application.CreateItem(olMailItem)
            fw.To = "boss@domain.com"
            fw.Subject = "Needs Approved"
            fw.Attachments.Add Item
            fw.Send
Item.Delete
BlackOps
Great help Diane. This is the code i am looking for.
S Outlook Email Help: Select custom voting button options VBA Outlook VBA and Custom Forms 1
S Email Help: Sending Outlook email from Excel VBA Outlook VBA and Custom Forms 6
A Help with VBA please! Outlook VBA and Custom Forms 15
M VBA SWcript Help Required Using Outlook 1
F No Attachment Warning - VBA Code HELP Outlook VBA and Custom Forms 1
C Beginner Needs VBA Help in Modifying Code Outlook VBA and Custom Forms 2
P VBA help window: Multiple windows/tabs, bookmarks, bookmarks/historypane Outlook VBA and Custom Forms 4
