Using Categories for Dynamic Distribution Lists
Diane Poremsky Create a list of color categories and merge or restore the list using VBA New Slipstick.com Articles 0
N Using Categories & Search Folders with multiple accounts Using Outlook 4
N Using categories in outlook with imap Using Outlook 1
J Add categories to Shared Mailbox using VBA Using Outlook 2
D Using categories in a shared calendar Using Outlook 1
N Using categories to send emails Using Outlook 9
S Using Categories in the Calendar Using Outlook 4
D using outlook 2007 categories through gmail Outlook VBA and Custom Forms 2
