How to keep reccurence during copy tasks to calendar?
mcwiciu
when I copy / move tasks to calendar the reccurence information is lost!
I've got many many tasks and restoring manually recurrence to each one is almost impossible!
It's very important to me to keep reccurence. i've tried move / copy / drag and drop / export - import (all formats) and it is always the same - reccurence is lost.
Is there any way to keep information about reccurence during copy from tasks to calendar?
Plz help
Thx
Did you switch to a list view, copy the item then paste it on the folder you're moving it to? (Use Ctrl+C, Ctrl+V to copy and paste if the commands aren't on the right click menu)
Right click drag should work too, as should open the folder and paste. But, especially in older versions of outlook, you want to use a list view as copying from the calendar views will often only select the event. You can check to see if right-clikc drag offers to copy the entire series - it does in some versions.
CWM030 Outlook 2016 with imap emails keep Resurrecting themselves? Using Outlook 5
O Wishlist Native solution to detach attachments but keep a link to them Outlook Wishlist 1
Scorpion New Contacts keep coming up as company Using Outlook 1
R Can't keep emails synced on various devices Using Outlook.com accounts in Outlook 4
piusg 2013: Task Views keep disappearing Using Outlook 4
Dan Badur How can I keep indenting OFF on replies in Outlook 2013? Using Outlook 1
S how to keep "To" when move sent emails to other folder Using Outlook 1
K Deleted emails keep coming back Using Outlook 3
A How to add personal notes to a meeting - and keep them if update sent? Using Outlook 1
A outlook trying to keep sending Using Outlook 1
B Closing Exchange service, how to keep all calendar and mail data? Exchange Server Administration 0
D How to keep Outlook 7 open to full screen Using Outlook 2
S How do I keep my old PST file as default Exchange Server Administration 1
Z Keep Unread Messages in same folder Using Outlook 2
L Oulook always "disconnected" how do I keep it open all of the time? Using Outlook 1
P emails with attachments keep sending... HELP!!! Using Outlook 4
M How do you keep sent emails in the PST folder in outlook 2013 Using Outlook 1
N Contact Groups - names keep changing from Contacts to AddressBook Using Outlook 5
M Reminders keep coming to users' calendar Exchange Server Administration 1
L Outlook 2010 - Keep getting "Corrupted File" Msgs Using Outlook 4
S Reminders keep popping up, even after dismissing them Using Outlook 9
P deleted items keep reappearing in my deleted folder Using Outlook 4
P Stationary and view layout keep changing after reboot? Using Outlook 1
D Users changing domains within a corp, but need to keep old address. Using Outlook 2
Y MICROSOFT OUTLOOK 2007 - i KEEP GETTING THE "ENTER NETWORK PASSWORD" BOX POPPING UP - IT IS ALREADY Using Outlook 4
A How to keep all conversations expanded? Using Outlook 3
S Deleted messages keep coming back Using Outlook 7
A Keep format of message in the body Outlook VBA and Custom Forms 1
R How do I keep old calendar events from disappearing? BCM (Business Contact Manager) 2
R keep track of the original sender Outlook VBA and Custom Forms 3
Diane Poremsky Data loss may occur during public folder migration New Slipstick.com Articles 0
Diane Poremsky Add Attachments and Set Email Fields During a Mail Merge New Slipstick.com Articles 0
Diane Poremsky Add attachments and set email fields during a mail merge to email New Slipstick.com Articles 0
D Outlook 2010 hangs during message send/receive Using Outlook 2
