Entering dates in Contacts and Calendar
Lizzie Bennet
Outlook 2007
I have made a customized contact form, using various fields (User Fields 1-4 were used up very fast) for data- I'm on Outlook 2007. I can then have a number of customized views. So, for instance, I wanted a field for the date that I first met with the contact. I randomly used, "ACCOUNT" as the field. When I then do a customized view for "aging"-- listing contacts in the order that I first met with them, I just use "ACCOUNT" as the field in the customized view, and of course, then name and other basic fields.
Here is my question: is there any way that I can enter the date for the meeting on the Calendar and it will then ALSO automatically populate in the "ACCOUNT" field? Or vice versa? Or enter it in another place and it will populate in both calendar and contacts?
Do you create appointments from the contact or create the appointment and link it to the contact (either using contact linking or by inviting them)?
If you normally go into contacts and select the contact then choose create new appointment, we can update the contact field fairly easily using a macro... but as long as you are on 2007, you can use Activities. You'll need to either invite the contact or add them to the Contact field for this to work.
To Link an Outlook Item to a Contact
To show the activities, click on the Activities button on the Contact tab. The first screenshot on Outlook 2010 & Contact Activities shows what it looks like.
ETA: I have a macro that i use to update the notes field when i send an invoice - that should work for this too.
i use this to look up a contact and create one if one is not found. it gets the email address from the selected email message and this line looks up the contact:
Set oContact = colItems.Find("[email1address] = '" & strTo & "'")
once you find the contact, you can update any field.
'-- Create Contact ---
Dim oNS As Outlook.NameSpace
Dim folContacts As Outlook.MAPIFolder
Dim colItems As Outlook.Items
Set oNS = Application.GetNamespace("MAPI")
Set folContacts = oNS.GetDefaultFolder(olFolderContacts)
Set colItems = folContacts.Items
If Not (oContact Is Nothing) Then
oContact.Body = StrSubject & vbCrLf & strNote & vbCrLf & _
         "Client time: " & strTime & "My time: " & strMyTime & _
         vbCrLf & "------------------------------------------------" & vbCrLf & oContact.Body
         oContact.Save
         oContact.Display
Set oContact = Application.CreateItem(olContactItem)
With oContact
.Body = StrSubject & vbCrLf & _
.Email1Address = strTo
.Email1DisplayName = strName
.FullName = strName
.Categories = "ScheduleOnce"
.Save
.Display
Lizzie Bennet
Outlook 2007
Thank you. I was also pondering a way to do several other things and if I understand this correctly, this WILL do the several other, also, with some modifications. Thank you! Thank you! I'll advise once I try it a bit more. Right now I'm backing up my data, just in case...
We set up appointments for our contacts by adding it to the calendar, only, and do not create a contact until the time of the appointment, for a variety of rational reasons. Despite how it sounds, we have been doing this with a keyboard and not a chisel and hammer for, gee, at least 2 months now.
remove the code that creates the contact and do something else (exit sub or something to avoid errors)
B Outlook tasks: due date changes after entering reminder or start dates Using Outlook 2
A OL13 Calendar, won't allow entering 2 appointments consecutively Using Outlook 4
J Entering Contacts at Same Company Using Outlook 1
W Go to search field when entering a contact folder? Using Outlook 2
S Entering new contacts in Outlook 2010 - they go to the same catagory. Using Outlook 2
Z Syntax for entering same statement as a reply Outlook VBA and Custom Forms 2
Z Outlook for G Suite emails showing wrong dates Using Outlook 4
O Outlook 2016 follow-up flags--how can I add dates? Using Outlook 1
O highlighted dates in Yearly View for Outlook 2010 Using Outlook 1
B Extract Dates for Appointment Item in Body of email Outlook VBA and Custom Forms 10
1 Incorrect dates in sent folder Using Outlook 4
C Many Expiration Dates in Custom Form Using Outlook 1
N To Do bar showing incorrect due dates on tasks Using Outlook 4
O automate dates in outlook template Using Outlook 1
R adding anniversary dates in outlook Using Outlook 2
B Birthday dates automatically (and improperly) placed in Birthday Details Using Outlook 2
D Task Start and Due Dates Using Outlook 3
T Conditional dates in Outlook Calendar Exchange Server Administration 1
C Dates changes to 1899 when Tab key hit in Time... Using Outlook 3
C dates missing when importing emails Using Outlook 5
S Inserting Dates With Quick Parts (or Macros) Using Outlook 4
K Recurring Tasks on specific dates, not pattern Using Outlook 0
S Reminders and Due Dates in Outlook 2010 Using Outlook 6
T Dates are not in bold from a shared calendar (Outlook 2010 ) Using Outlook 1
M Outlook does not bold calendar dates when events are scheduled for those dates. Using Outlook 1
T How to display dates from other calenders in task list Using Outlook 1
F Outlook message receive dates are wrong. How do I fix? Using Outlook 1
T Outlook Print drops dates Using Outlook 3
V Set-MailboxCalendarFolder -PublishDateRangeTo (How to set to ALL dates?) Exchange Server Administration 8
F Correct email dates corrupted during importing from Outlook Express Using Outlook 1
O How do I copy and paste calendar dates in 2010 outlook? Using Outlook 1
M Importing dates from Excel into Outlook Using Outlook 2
M How do I set default dates for deletion of mailboxes in disconnected status Exchange Server Administration 2
D Sending Multiple Meeting Dates in One Meeting Request Using Outlook 4
A Is there a calender preference for Julian Dates in outlook? Using Outlook 4
T Copy/export dates/times from Inbox table view Outlook Wishlist 1
T comparing and subtracting sent and received dates Outlook VBA and Custom Forms 3
D offline fatabase on laptop not remembering TASKS dates BCM (Business Contact Manager) 1
J Get Dates of Recurring Events in Shared Appointment Calendar Outlook VBA and Custom Forms 4
