PROBLEM REGARDING OUTLOOK STORAGE LANGUAGES
GIRISH
Hi Diane Poremsky,
Madam, I am using Outlook 2010 with the help of Core Public Folder Application (C2). I have four PCs connected on local network in my office. I am using Outlook in each PC for contact details & data storage. I want to make my storage in two different languages i.e. English & Hindi but I am facing the problem regarding that. Whenever I create a field and type in regional language it appears as question marks in other user pc Outlooks. After that if I make any changes in those fields in other user Outlook and save that data, same question marks appears in all user pc Outlooks i.e. ????
Please help me for the problem I am facing.
If they aren't shared using a method that supports Unicode, you'll get question marks or boxes for the high characters when they are shared. I don't know if the PF utility does...
What language is version is Office? Do you have the "other" language pack installed on the computers?
GIRISH
Hello Diane Poremsky,
Madam, I do not know what is Unicode or PF utility. I am just a user and not familier with these technical things. I have MS Office 2010 installed in my computer. I also have shared image of languages I have installed in my computer. Can you provide a direct solution for my problem i.e. if you are providing a paid solution service, I am ready to purchase it.
i'm not sure i can fix it... have you asked the codetwo people about it?
GIRISH
OK...... Thanks we will ask to code two person and will come back to you
B Problem with import Excel BCM (Business Contact Manager) 1
chupacabra Problem with IMAP .pst file Using Outlook 13
