Macro to Copy Specific content from Mail Body and Paste to Excel
Harish Shrivastava
Outlook 2013 32 bit
Please help me out with an Outlook macro which copies and pastes specific (mentioned below) text from mail body and paste it to excel sheet one after another.
Test to copy looks like:
File Date: 8/19/2016 4:25:20 AM
File Size: 159457 bytes
Records: 8586
This should be pasted horizontally. Only the data after the colon.
What i want is whenever an email comes to a specific folder the macro should run and it should copy the data to excel automatically.
It would be a great help guys. Thanks in advance :)
Harish Shrivastava
Outlook 2013 32 bit
Thank you Diane for the reply. It would be really helpful if you help me out with below 2 additions in your code as given in the article:
1. The macro should get the text from an email every time it comes to a particular inbox folder
2. It should paste the text in an Excel sheet one after one.
Thank you for your help.
Replace the code in Use a macro to copy data in Outlook email to Excel workbook between the With Reg1 and the End If block right before xlSheet.Range("B" & rCount) = vText with the following.
Change the macro name to
Private Sub objItems.ItemAdd(ByVal Item As Object)
Then get the first macro at How to use an ItemAdd Macro and set the folder you want to watch. Working with VBA and non-default Outlook Folders has info on how to refer to different folders.
(the macros all go into ThisOutlookSession)
For i = 1 To 3
With Reg1
    Select Case i
    Case 1
        .Pattern = "File Date:\s((.*))\n"
        .Global = False
    Case 2
       .Pattern = "File Size:\s(([\d]*))\n"
       .Global = False
    Case 3
        .Pattern = "Records:\s(([\d]*))\n"
        .Global = False
    If Reg1.test(olMail.Body) Then
        Set M1 = Reg1.Execute(olMail.Body)
        For Each M In M1
            Debug.Print M.SubMatches(1)
            strSubject = M.SubMatches(1)
         if i = 1 then vText = strSubject
         if i = 2 then vText2 = strSubject
         if i = 3 then vText3 = strSubject
Next i
I *think* those patterns will work - you might need to tweak them a bit though. And, of course, you'll need to refer to the correct workbook and sheet.
Diane Poremsky Use a macro to copy data in Outlook email to Excel workbook New Slipstick.com Articles 0
T Macro to find contacts by category and copy them to another folder Outlook VBA and Custom Forms 15
A Macro to Copy Data from Outlook to Excel Spreadsheet Using Outlook 2
Aussie Looking for Outlook macro to Copy Recipient Names into Email Body Outlook VBA and Custom Forms 3
A Macro to copy email body to new email Outlook VBA and Custom Forms 5
R Macro to copy email address Using Outlook 6
L Macro to add Date & Time etc to "drag to save" e-mails Outlook VBA and Custom Forms 1
