Saving Outlook attachments and links to attachments with VBA
Chris Hewitt
Outlook 2013 32 bit
Hello to all, I am a captain of a fairly large and active volunteer Ambulance corps just outside of a major metropolitan area.
Every few days I receive intelligence documents (as do - or should - almost all fire chiefs and peer ambulance captains in the US).
Informational ones come as PDF attachments but the really important ones come as URLs to the PDF file that expire and disappear in a few days (and some in hours).
The problem is that my day job often is so time consuming that I miss the critical PDF documents pointed to by the links.
What I could use help with is a SUB where I can pass a sender email address, Windows folder for documents to be saved in (and maybe a folder (with an option to search subfolders) or just default to the current INBOX). Then the macro will look for every email sent by that email address and save all the PDF attachments and if there is a link to a PDF file save that as well - maybe only look at unread messages to improve efficiency and speed.
Anyone able to help me out here?
PS. have lots of technical experience - started with VisiCalc way back when ... and now the gun for hire on Excel macro issue at a global investment bank. BUT I have no Outlook VBA experience and need this solution ASAP as I am missing too many important documents.
The macro here - Open All Hyperlinks in an Outlook Email Message - will open all links in a message. The run a script version works in a rule - put the sender address in it.
I have other macros that can save attachments off of email - you can put them together in to one.
That will open the link and as long as you don't need to do anything else, will download the file. If you are unable to set a default for downloads, you could use clickyes to respond to the dialog.
D Saving outlook emails in html and attachments Using Outlook 4
T Outlook 2007 alters date when saving attachments, windows 7. Using Outlook 5
V Saving attachment from outlook in My Documents Outlook VBA and Custom Forms 14
R Outlook 2010 Modify Style "Do not check spelling or grammar" not saving Outlook VBA and Custom Forms 0
R Outlook Office 365 not saving addresses Using Outlook 0
J Outlook 2013 crashes saving VBA & clicking tools | digital signature Outlook VBA and Custom Forms 1
L Outlook DST (Daylight Saving Time) problem Using Outlook 0
F Using Outlook 2007 as an IMAP Mail Station Without Saving Data Locally Using Outlook 2
D File Lock issue when saving message from Outlook to new folder Using Outlook 1
K Printing & Saving Outlook Contacts Using Outlook 3
R Outlook 2007 QAT buttons not saving Using Outlook 2
C Exchange 2003 - Outlook 2003 - Calendar entries saving over each other Using Outlook 2
J Saving Published Outlook Form as msg Using Outlook 1
J Saving Incoming & Outgoing Outlook 2010 Email Locally with IMAP Using Outlook 2
O Outlook Today Customization not saving in Outlook 2010 32-bit Using Outlook 9
R Saving Outlook Email As Text File Extract Outlook VBA and Custom Forms 2
D Outlook 2003 Saving into a textbox when form closes Outlook VBA and Custom Forms 3
T Saving Embedded Images in Outlook 2007 Outlook VBA and Custom Forms 3
D Outlook 2003 saving option button Outlook VBA and Custom Forms 1
B Saving items under a folder Using Outlook 3
I Dialog called up multiple times when saving emails from macro Outlook VBA and Custom Forms 2
T Saving all email to file folder in Windows Using Outlook 2
Kevin H Remotely saving emails Using Outlook 1
P Saving All Messages to the Hard Drive Using VBA Outlook VBA and Custom Forms 5
S Editing an email with notes and saving it for record using Macro Outlook VBA and Custom Forms 3
bifjamod Saving sent email to specific folder based on category with wildcard Outlook VBA and Custom Forms 1
N Saving .msg as sent item on send Outlook VBA and Custom Forms 1
erichamion Changes to meeting body not properly saving Outlook VBA and Custom Forms 4
A ItemAdd on Imap Folder get endless loop after saving item Using Outlook 5
T From Field Blank when saving to folder other than Sent items Using Outlook 2
E Saving Changes To Edited E-Mail Received Message Using Outlook 0
D Remove extension while saving attachments Using Outlook 1
S Not saving attachments in the Sent Folder Using Outlook 2
W Default Saving a message as text Using Outlook 2
B How to choose which contacts folder to use when saving contacts? Using Outlook 1
