Categorise emails on sending - macro not working in Preview mode
panesai1
Outlook 2013 32 bit
I use the following macro to assign a category to any outgoing email message (Outlook 2013)
'Categorize Sent Items
'Place in ThisOutlookSession
If TypeOf Item Is Outlook.MailItem And Len(Item.Categories) = 0 Then
Set Item = Application.ActiveInspector.CurrentItem
Item.ShowCategoriesDialog
The macro works fine when the email message is "Popped out" into its own window.
However, when i work within the Outlook Reading pane (e.g. clicking Reply or Reply-to-all from within the Outlook reading pane) and then try to send without popping the composed message into its own window pane, the macro does not work.
I get the macro debugger alert highlighting the following error prompt:
Runtime error 91
Object variable or With block variable not set.
Is this a Outlook 2013 bug?
many thanks
C Multiple emails Using Outlook 1
Phillip Bit.ly emails Using Outlook 1
G Alerting on missed emails in conversation Outlook VBA and Custom Forms 1
P Outlook for Mac - emails are not sent out beginning last week Using Outlook 1
N Extract Outlook emails to excel Outlook VBA and Custom Forms 2
M Group of emails Using Outlook 1
D Assign categories to outgoing emails Outlook VBA and Custom Forms 0
P Flagging emails in conversations Using Outlook 2
D Outlook 2016 Deleting emails without affecting folder structure - Outlook Office 365 Using Outlook 3
M Filter Conversations - Filter Out Single Emails Outlook VBA and Custom Forms 3
F not receiving emails until i re-login Using Outlook 2
A Record opened emails for reopening later Outlook VBA and Custom Forms 16
R Deleting emails from storage folder Outlook VBA and Custom Forms 1
S How can I delete all copies of a given companies logo graphic from all my emails at once? Using Outlook 3
L Time format in Outlook calendar and emails Using Outlook 0
G Parsing All Emails Outlook VBA and Custom Forms 8
J Set Timer/Countdown on Emails? Outlook VBA and Custom Forms 3
T Render Outlook emails in MS access as they appear in Outlook Outlook VBA and Custom Forms 2
O Delete duplicate emails - subscription notifications Using Outlook 5
V Emails remain in Drafts folder even though they have been sent Using Outlook 4
T Deleting duplicate emails Using Outlook 2
N Copies of emails from rules have wrong from: account Using Outlook 0
V Emails going into Drafts instead of Sent folder Using Outlook 3
H tracking time of emails Outlook VBA and Custom Forms 2
