VBA Rule for removing all body but hyperlink then forwarding
Majunga
Outlook 2013 64 bit
I want to create an Outlook rule using a script that will forward an e-mail to my cell phone, keeping the same subject, and removing the majority of the body of the e-mail. The only part of the body I'd like to keep is a hyperlink, and the hyperlink can be listed in two ways: 1) a standard hyperlink (i.e. https://www.google.com) and 2) a hyperlink embedded in text (i.e. Google).
I'm currently using a script that does half of this. It forwards the e-mail but removes the body. It may be easiest just to modify my existing script. Here's the code:
Public Sub SMS(msg As MailItem)
  Dim olMailFwd As MailItem
  Set olMailFwd = msg.Forward
  With olMailFwd
      .HTMLBody = ""
      .Subject = msg.Subject
      .To = "5551234567@carrier.com" 'enter phone number e-mail address here
  olMailFwd.Send
  Set olMailFwd = Nothing
I tried adapting the code found here under the "Find a code in the message body, then forward" section: Run a Script Rule: Change Subject then Forward Message, but even when I try to use this code unmodified, I get an error saying " Run-time error '5': Invalid procedure call or argument. When I debug, it highlights this line of code:
Item.Subject = M.SubMatches(1) & "; " & Item.Subject
Majunga
Outlook 2013 64 bit
Sorry about the code tags. Whenever I tried to add them, I received an error.
there is a bug in a recent forum update - inserting urls only works if http:// is removed - I wasn't aware code tags also failed. :(
This shows how to find links and assign the link to a variable, which you can then insert into the body using .body = strurl.
Open All Hyperlinks in an Outlook Email Message
the macro at Run a Script Rule: Change Subject then Forward Message is similar - you just need the correct pattern and put it in the body, not subject.
I'll have to see if we can pick up hyperlinks using word vba - if so, it would be embedded just as it appears in the email.
it's likely because there is no pattern match. oh, or its because you didn't set a reference to the regex object library.: Microsoft VBScript Regular Expressions 5.5
Majunga
Outlook 2013 64 bit
I must have done something wrong. While I'm not getting any errors and the message is forwarding, it is forwarding with a blank body. Here's the code:
Public Sub SMStest(msg As MailItem)
    Dim Reg1 As RegExp
    Dim M1 As MatchCollection
    Dim M As Match
    Dim strURL As String
Set Reg1 = New RegExp
With Reg1
    .Pattern = "(https?[:]//([0-9a-z=\?:/\.&-^!#$;_])*)>"
    .Global = True
    .IgnoreCase = True
If Reg1.Test(msg.Body) Then
Set M1 = Reg1.Execute(msg.Body)
    For Each M In M1
        strURL = M.SubMatches(0)
        Debug.Print strURL
   With olMailFwd
       .HTMLBody = stURL
olMailFwd.Send
Set Reg1 = Nothing
I'm not going to comment on how long it took me to see the problem... :) but
.HTMLBody = stURL is spelled wrong, it should be strURL.
you might need to use .Body = strURL if its not clickable.
The code gets the last url - to get the first, use
.Global = False
Majunga
Outlook 2013 64 bit
Yup, I ended up writing the script over again and realized that was the problem after I mistakenly typed it wrong a second time.
So, it's working now that I've made that correction. How difficult do you think it would be to modify it further so that it can pull multiple hyperlinks from the e-mail instead of just one, and send those hyperlinks in one single forward?
This variation gets the last link and pastes it as formatted text (embedded link)
Dim objInsp As Outlook.Inspector
Dim objDoc As Word.Document
Dim objSel As Word.Selection
With olMailFwd
Set objInsp = olMailFwd.GetInspector
With objSel
.WholeStory
Dim H As Word.Hyperlink
For Each H In objDoc.Hyperlinks
H.Range.Select
.Copy
Next H
olMailFwd.Body = ""
objSel.PasteAndFormat (wdFormatOriginalFormatting)
olMailFwd.Display
BTW, to test the code (or any run a script code) without sending messages, you can use this stub - select a message then run this code to call the macro.
Sub RunScript()
Dim objItem As MailItem
Set objApp = Application
SMStest objItem
Also, because the macro in the message above doesn't check for http, it gets the last link, which could be a mailto.
You can use something like this to filter for a word in the address -
If InStr(lcase(H.Address), "word") <> 0 Then
.copy
end if
Not hard - you just need to tweak it - with the strURL code, do something like
strURL = strURL & vbcrlf & M.SubMatches(0)
The word code sample is a little more difficult - you need to scan the original message and write he links as you go.
O VBA rule on multiple computers using shared mailbox Outlook VBA and Custom Forms 1
I shared mailbox - can i create a rule (vba) for every user? Outlook VBA and Custom Forms 1
Gary Brown Outlook 2013 VBA to run a rule Outlook VBA and Custom Forms 13
N VBA, Rule that will Auto Reply based on time of day Outlook VBA and Custom Forms 1
C Further automate several tasks with rule, VBA or Quick Step Using Outlook 1
D Update existing rule using VBA Using Outlook 2
R vba rule exception "except with specific words in the sender's add Outlook VBA and Custom Forms 2
R Outlook 2003/2007 Rule and Conditions for InBox VBA customization Outlook VBA and Custom Forms 3
K Re: Cuestom outlook rule using vba Outlook VBA and Custom Forms 4
S Excel VBA and shared calendar issue Outlook VBA and Custom Forms 4
R Limiting length of saved attachment in VBA Outlook VBA and Custom Forms 2
B VBA to Collapse Task Folder Groups Outlook VBA and Custom Forms 1
shrydvd vba to secure zip attachments Outlook VBA and Custom Forms 3
