Saving attachments from specific sender (phone number) to specific folder on hard drive
JayMcBATX
Outlook 2016 64 bit
I can set our phone system to send notifications with an .wav file attachment of the voicemail. The sender as well as the name of the attachment indicates which phone line the message is associated with. Based on which phone number the message is associated with, I would like to save it to a specific folder on my hard drive.
For example: I get an email with a wav attachment named 2145551212.2432434.wav from 214.555.1212 (no reply). I would like to automatically save that file to folder c:sharesync\2145551212 and have the date included in the new file name. Can anyone help with how to do that?
The macros at http://www.slipstick.com/developer/code-samples/save-messages-and-attachments-in-a-new-folder/ should get you pointed in the right direction.
Or this page - http://www.slipstick.com/developer/code-samples/save-rename-outlook-email-attachments/ - it has a run a script rule example if you want to do it as the messages arrive.
You can get the number to use from the attachment name easily and adding the date to the file name is simple - there should be examples of that on those pages.
JayMcBATX
Outlook 2016 64 bit
Can I have multiple rules that place the attachment in a specific file folder based on the sender? We have multiple phone lines and I need the files in separate folders for each.
C Saving Outlook attachments and links to attachments with VBA Outlook VBA and Custom Forms 2
D Remove extension while saving attachments Using Outlook 1
S Not saving attachments in the Sent Folder Using Outlook 2
D Saving outlook emails in html and attachments Using Outlook 4
T Outlook 2007 alters date when saving attachments, windows 7. Using Outlook 5
S Automate saving of attachments on new incoming emails Outlook VBA and Custom Forms 3
J Saving Attachments Outlook VBA and Custom Forms 1
D Outlook 2016 Outlook not saving Sent Items Using Outlook 4
B Saving items under a folder Using Outlook 3
V Saving attachment from outlook in My Documents Outlook VBA and Custom Forms 14
I Dialog called up multiple times when saving emails from macro Outlook VBA and Custom Forms 2
T Saving all email to file folder in Windows Using Outlook 2
Kevin H Remotely saving emails Using Outlook 1
R Outlook 2010 Modify Style "Do not check spelling or grammar" not saving Outlook VBA and Custom Forms 0
R Outlook Office 365 not saving addresses Using Outlook 0
P Saving All Messages to the Hard Drive Using VBA Outlook VBA and Custom Forms 5
S Editing an email with notes and saving it for record using Macro Outlook VBA and Custom Forms 3
J Outlook 2013 crashes saving VBA & clicking tools | digital signature Outlook VBA and Custom Forms 1
bifjamod Saving sent email to specific folder based on category with wildcard Outlook VBA and Custom Forms 1
N Saving .msg as sent item on send Outlook VBA and Custom Forms 1
erichamion Changes to meeting body not properly saving Outlook VBA and Custom Forms 4
A ItemAdd on Imap Folder get endless loop after saving item Using Outlook 5
T From Field Blank when saving to folder other than Sent items Using Outlook 2
L Outlook DST (Daylight Saving Time) problem Using Outlook 0
F Using Outlook 2007 as an IMAP Mail Station Without Saving Data Locally Using Outlook 2
E Saving Changes To Edited E-Mail Received Message Using Outlook 0
D File Lock issue when saving message from Outlook to new folder Using Outlook 1
K Printing & Saving Outlook Contacts Using Outlook 3
W Default Saving a message as text Using Outlook 2
R Outlook 2007 QAT buttons not saving Using Outlook 2
C Exchange 2003 - Outlook 2003 - Calendar entries saving over each other Using Outlook 2
J Saving Published Outlook Form as msg Using Outlook 1
B How to choose which contacts folder to use when saving contacts? Using Outlook 1
J Saving Incoming & Outgoing Outlook 2010 Email Locally with IMAP Using Outlook 2
F Saving Imap Drafts Using Outlook 1
J saving contact info in specific address books Using Outlook 0
