Outlook 2010, 2013 will not open .msg or .eml files
Ian Thomas
Outlook 2013 64 bit
Outlook.com (as MS Exchange)
This is possibly a bit off-topic, but I haven't found a reason for this. (and it may be in the wrong forum)
I have .msg files saved by either Outlook 2010 or 2013 desktops, or .eml files saved a long time ago from Outlook Express (etc).
I cannot open them by double-clicking on the file (from Windows Explorer) when Outlook is active (or inactive). Windows 10 Pro, 64-bit.
In earlier Windows with Outlook 2010 desktop I do know that I routinely opened saved .msg (and .eml) files, as they are relevant to projects in combination with other documents.
This is the error message that results -
i'm assuming outlook is set as the default for everything... it might be because you have 64-bit outlook installed - that tends to cause weird issues like this. You definitely should be able to open them tho.
Do you have all updates installed for your version of Outlook? Try a repair.
I have some information here - Outlook is Not Recognized as the Default Email Client
J Outlook 2010 and 2013 'team' calendar shows AD accounts without mailboxes Using Outlook 5
P Outlook 2013 Office 2010 Hybrid Using Outlook 4
Diane Poremsky How to remove the primary account from Outlook 2010/2013 New Slipstick.com Articles 0
Forum Admin BCM Update for Outlook 2010/2013 - Nov 2014 BCM (Business Contact Manager) 14
B 0x800CCC0F Error using POP3 in Outlook 2010 and 2013 Using Outlook 1
Fozzie Bear Outlook 2010 or 2013 Dual Configuration Exchange + IMAP Exchange Server Administration 6
G Need help configuring a PRF for Outlook 2010 and 2013 Using Outlook 0
P Copy email address from outlook 2013/2010 Using Outlook 1
T Downgrade from Outlook 2013 to Outlook 2010 Using Outlook 6
S Moving folders from outlook 2010 to a new computer with outlook 2013 Using Outlook 1
W Importing .pst from Outlook 2010 (Win7) to Outlook 2013 (Win8.1) Using Outlook 2
V Outlook 2013 cant stay connected to exchange 2010 Exchange Server Administration 5
P Outlook 2013 search broken after upgrade from 2010 Using Outlook 0
R Exchange 2013/Outlook 2010 Slow Startups Exchange Server Administration 8
G Deleting AOL Emails form Outlook 2010 or 2013 Using Outlook 1
J Update Outllook 2010 to Outlook 2013 - Incorrect Forms Using Outlook 2
D Will Outlook 2010 work with Office 2013 H&S that was preinstalled Using Outlook 2
V 2010 outlook issue after uninstalling 2013 Using Outlook 5
J Office + Outlook 2013 installed, but I need to install Outlook 2010 Using Outlook 2
