Contacts folders not syncing with hosted exchange
Flussig
Exchange Server 2013
Hi there.
I have moved a client onto hosted exchange so that they can better manage the contacts within the business.
They have a lot of people moving inbetween locations and having the contacts split into folders will help with out of sync data issues.
I have set up the contact folders and added in the contacts at my office and as it's a hosted exchange service they should sync over to the clients desktops. However only part of this is happening, the contacts and the folders are syncing however when going into address book the folders are not showing.
Can any shed some light on this?
Flussig
Thanks for your reply Diane.
It's been at least a couple of days, however i have managed to figure it out.
You need to tick the option to 'Show this folder as an e-mail address book' in the folder properties as shown in the image.
Ah... yeah... that is important and easily overlooked.
L Merge two contacts folders Using Outlook 1
Cdub27 Move Outlook 2016 Contacts to Other Folders - Extremely Slow !! Using Outlook 6
O Contacts folders, outlook 2016 Calendar Printing Assistant 0
I Outlook 2013 Contacts groups, folders Using Outlook.com accounts in Outlook 1
I Many empty Contacts folders.. cannot get rid of them Using Outlook 4
R Contacts/Personal Folders, etc Using Outlook 5
E Outlook2010 contacts folders messed up Using Outlook 6
S Missing Contacts Folders Using Outlook 6
T managing contacts in public folders Using Outlook 4
M Access replicated Outlook (email folders, calendar, contacts, notes) via web Using Outlook 1
M creating multiple contacts for CONTACTS folders from multiple messages INBOX Using Outlook 4
S Outlook 2010: How do you enable Contacts' Activities to search archive folders Using Outlook 6
A Are Public Folders Contacts available through activesync for Windows Phone 7, Iphone, etc? Exchange Server Administration 3
D How to remove "extra" contacts folders in Outlook 2010 Using Outlook 4
L Favorites for People/Contacts? Using Outlook 1
F Moving Contacts to New Profile Using Outlook 0
V Contacts in O365 have changed?? Using Outlook 20
GregS Exporting contacts Using Outlook 1
egarneau Meeting updates with external contacts (GMail) Using Outlook 1
bhamberg Contacts in a category Outlook VBA and Custom Forms 11
E GAL Attributes to Contacts Using Outlook 0
