GetTable Add body
oliv-
is it possbile to add "Body" to Table from GetTable ?
Sub testGetable()
    Dim oFolder As Outlook.Folder
    Dim criteria
    Dim oTable As Table
    Dim i, oRow, r, arr
    Set oFolder = Application.Session.PickFolder
    criteria = "[MessageClass]='IPM.Note' or [MessageClass]='IPM.Post'"
    Set oTable = oFolder.GetTable(criteria, olUserItems)
    With oTable.Columns
        .add ("Body")
    MsgBox oTable.GetRowCount
    Set oRow = oTable.GetNextRow()
    MsgBox oRow("Subject")
    MsgBox oRow("Body")
I have an error 5 Invalid procedure call or argument
Michael Bauer
No. The boolean property "urn:schemas:httpmail:hasattachment" reveals only whether or not it has attachments. For details you need to open the message.
oliv-
That's what I thought. Thank you
B Task Filter Not Working When I add too many criteria Using Outlook 0
D Add Tetxbox at form open Outlook VBA and Custom Forms 1
Andrew Quirl Open attachment, manipulate without add-on program? Outlook VBA and Custom Forms 5
B Searching for a Add-In Using Outlook 3
J Add Fillable Fields to Existing Template Outlook VBA and Custom Forms 1
J vb to c# for Outlook add-in. Using Outlook 0
twofivepie GTD Netcentrics add-in for 2016 Outlook VBA and Custom Forms 13
D Add all meeting rooms to the meeting request by default Outlook VBA and Custom Forms 0
A add birthday to outlook contacts Using Outlook 1
Commodore Microsoft Exchange Add-in Using Outlook 2
skyfox Add folders inside a PST. How? Outlook VBA and Custom Forms 3
