property "is printed" or catching print events
oliv-
Does an Email have a "printed" property ?
Is there a way to catch prints events ? (click in the backstage command Print, Click the Ribbon, or Ctrl+P)
oliv-
Thank you, This is also what I thought
G Store.FilePath Property Outlook VBA and Custom Forms 4
W Appointment occurrences change the location property Using Outlook 0
B Assistance with Deprecated .Links Property Outlook VBA and Custom Forms 2
JorgeDario ¿What property of mailitem can be used like primary key? Outlook VBA and Custom Forms 6
M Accessing ExpiryTime property Outlook VBA and Custom Forms 1
M How to automatically refresh an appointment windows after changing the MessageClass property ? Outlook VBA and Custom Forms 4
R Vba Conversation Index property Using Outlook 0
H Calendar Folder property is empty Using Outlook 1
G run-time 438: object doesn't support this property or method Using Outlook 2
Commodore Calendar Folder property is missing - Event 27 Using Outlook 11
B Update Item.Subject property Using Outlook 1
S Custom property/functionality not stored when I publish to a Public Folder Using Outlook 7
T You must Provide a value for this property on powershell cmdlet Exchange Server Administration 3
S Saved Property of MailItem is copied Outlook VBA and Custom Forms 1
M MailItem object has no property for when a reply was sent Outlook VBA and Custom Forms 3
D Using the CurrentFolder property Outlook VBA and Custom Forms 3
S Property pages in Outlook 2010 Outlook VBA and Custom Forms 1
M Can't create new user property? Outlook VBA and Custom Forms 10
S Xref type property in an email header? Outlook VBA and Custom Forms 6
W Setting PR_CREATION_TIME property? Outlook VBA and Custom Forms 1
D Item Property CHange Outlook VBA and Custom Forms 4
W Using a PropertyAccessor custom datetime property in Views Outlook VBA and Custom Forms 3
J How do I access the AssignedTo property in an outlook 2007 task? Outlook VBA and Custom Forms 7
S User property for folder Outlook VBA and Custom Forms 2
T Setting a MAPI property of type PT_SYSTIME Outlook VBA and Custom Forms 4
E Displayname of User Property Outlook VBA and Custom Forms 7
M Obtain property value by name Outlook VBA and Custom Forms 5
M Can't change autoarchive property in Deleted Items folder BCM (Business Contact Manager) 1
C How do I grab a field property (like .value) so I can modify it via OL code? Outlook VBA and Custom Forms 4
T recipient email address is invalid, but resolved property is true Outlook VBA and Custom Forms 3
M What is the recommendet way to read/write a user defined Field (Named Property) in the MailItem Obje Outlook VBA and Custom Forms 1
M What is the recommendet way to read/write a user defined Field (Named Property) in the MailItem Obje Outlook VBA and Custom Forms 5
V incorrect html signature printed Using Outlook 2
K Outlook 2010 Mailtips - Can they be printed with the email message Using Outlook 1
J CPA cuts off left edge of printed Calendar. Ex. January the J is cut off. Calendar Printing Assistant 11
M user-defined properties in printed emails? Outlook VBA and Custom Forms 8
U Catching ModuleSwitch events after "open in new window" Outlook VBA and Custom Forms 2
