VBA Script to move item in secondary mailbox
Qaadir
I have a script looking for a specific attachment name then forwarding it to a new recipient. Once this mail is sent it then has to move the original mail into a sub folder under the inbox.
This works when using it on my primary email account but I need this to run on a secondary account.
here is the code i have thus far please assist would be greatly appreciated.
Sub RequestForm(olItem As MailItem)
Dim olAtt As Attachment, ol_newmail As MailItem
For Each olAtt In olItem.Attachments
If InStr(1, Left(olAtt.FileName, 8), "FileName") > 0 Then
Set ol_newmail = olItem.Forward
ol_newmail.To = "newrecipient@email.com"
ol_newmail.Send
Sub MoveForm(Item As Outlook.MailItem)
For Each olkAtt In Item.Attachments
If Left(LCase(olkAtt.FileName), 8) = "filename" Then
Item.Move Session.GetDefaultFolder(olFolderInbox).Folders("DistinationFolder")
Exit For
Set olkAtt = Nothing
Im assuming this is because I am using default folder but cant i just add the email account name somewhere within the Item.Move command
Qaadir
Hi Michael
Thank you for the reply i haven't been able to test as yet once I do I will revert back. I am relatively new to this so only playing around right now.
J Email Parsing VBA Script for Outlook - NEEDED Outlook VBA and Custom Forms 7
R Adding vba to script list Outlook VBA and Custom Forms 4
F VBA script to highlight specific words Outlook VBA and Custom Forms 1
D VBA Script to extract text matching specific criteria Outlook VBA and Custom Forms 1
M VBA script to allow mail merges of distribution groups? Using Outlook 7
D VBA script to auto download attachments and rename file according to subject line Outlook VBA and Custom Forms 23
Hudas Outlook VBA script reverting back to previous changes Outlook VBA and Custom Forms 2
V "Accept + Send the Response now", VBA script? Using Outlook 1
R Addins4Outlook TagIt! addin script or VBA module? Using Outlook 2
A VBA Script to Forward Spam to AntiSpam Provider Using "Blank" Form Outlook VBA and Custom Forms 2
L Limit VBA Script to one Outlook account Using Outlook 1
