Using Data From Combo Box in Appointment Body
George Z
Outlook 2013 64 bit
I am attempting to take a different spin on the tutorial below:
Select from a List of Subjects before Sending a Message
I am attempting to utilize this form and macro for adding data to the body of an appointment item. Currently my macro utilizes input boxes to include several different data entries into the appt.body
I would love to add data to the appt.body using both input boxes and combo boxes. However if I add the form, code, and macro code. The input box data overrides the combobox data.If I rem the appt.body inputbox data the combobx adds the data to the body. It seems either one or the other will populate the body not both.
Any way of utilizing bot input boxes and combo boxes to the appt.body? Or any way for the userform to include both text box and combo box data to the appt.body?
Sub CreateMeetingatContactLocation()
Dim oOL As Outlook.Application
Dim NS As Outlook.NameSpace
Dim objOwner As Outlook.Recipient
Dim objAppt As Outlook.AppointmentItem
Dim objAppointment As Outlook.AppointmentItem
Dim objContact As Outlook.ContactItem
Dim strPhone As String
Set NS = Application.GetNamespace("MAPI")
  Set objOwner = NS.CreateRecipient("customerdb@beatonindustrial.com")
    objOwner.Resolve
If objOwner.Resolved Then
    'MsgBox objOwner.Name
Set newCalFolder = NS.GetSharedDefaultFolder(objOwner, olFolderCalendar)
Set oOL = Outlook.Application
Set objAppt = newCalFolder.Items.Add("IPM.Appointment.Beaton Service Form 4.3")
Set objContact = oOL.ActiveExplorer.Selection.Item(1)
' oMail.Display
   UserForm1.Show
  '  MsgBox "user chose " & lstNo & " from combo"
    Select Case lstNo
    Case -1
         objAppt.Body = objAppt.Body
    Case 0
         objAppt.Body = "Subject 1"
    Case 1
         objAppt.Body = "Subject 2"
    Case 2
         objAppt.Body = "Subject 3"
    Case 3
         objAppt.Body = "Subject 4"
    Case 4
         objAppy.Body = "Subject 5"
inputdata = InputBox("Please Enter Service Technican and Van Number in the FollowinG Format 14 MM/TS")
inputdata1 = InputBox("Please Enter a Descpiption of the Problem")
inputdata2 = InputBox("If a Man Lift is Required to Complete Service please note if lift will be provided by Beaton or Customer. If no Manlift is Needed enter Not Required")
inputdata3 = InputBox("Please Enter Company Hours of Operation to Complete Service")
inputdata4 = InputBox("Please Enter Location and Status of Required Parts if Applicable. Enter N/A if Not Applicable.")
inputdata5 = InputBox("Please Enter the Priority Level of Equipment Failure and Date Customer is Expecting Service")
inputdata6 = InputBox("Please Enter any Other Additional Notes Relevant to Service Request, Customer Expectation, and or Technical Details")
inputdata7 = InputBox("Add Dropbox Link for any Related File Attachments")
' Use Company for Location
If objContact.CompanyName <> "" Then
    objAppt.Subject = inputdata & " , " & inputdata5 & ", " & objContact.CompanyName & ", - OR - " & objContact.FullName & " , Phone: " & objContact.BusinessTelephoneNumber & " , Cell: " & objContact.MobileTelephoneNumber
' Use Business address if available, else home address
If objContact.BusinessAddress <> "" Then
    objAppt.Location = objContact.BusinessAddressStreet & "," & objContact.BusinessAddressCity & "," & objContact.BusinessAddressState & "," & objContact.BusinessAddressPostalCode
    strPhone = objContact.BusinessTelephoneNumber
  objAppt.Location = objContact.HomeAddressStreet & ", " & objContact.HomeAddressCity & " " & objContact.HomeAddressState & " " & objContact.HomeAddressPostalCode
    strPhone = objContact.HomeTelephoneNumber
' Add contact's name and phone number to the body
    objAppt.Body = "DESCRIPTION OF PROBLEM: " & inputdata1 & vbNewLine & vbNewLine & "MANLIFT: " & inputdata2 & vbNewLine & vbNewLine & "HOURS OF OPERATION: " & inputdata3 & vbNewLine & vbNewLine & "REQUIRED PARTS AND STATUS: " & inputdata4 & vbNewLine & vbNewLine & "ADDITIONAL NOTES: " & inputdata6 & vbNewLine & vbNewLine & "FILE ATTACHMENTS: " & inputdata7
    objAppt.Display
Set objAppointment = Nothing
If objAppointment Is Nothing Then
                With objAppt
                .AllDayEvent = True
                .BusyStatus = olBusy
Set objContact = Nothing
Set oOL = Nothing
It should work.... you need to use something like this:
for the cases:
Case -1
strBody = objAppt.Body
Case 0
strBody = "something else"
then use
objappt.body = strbody & vbcrlf & inputdata & vbcrlf & inputdata1...
George Z
Outlook 2013 64 bit
Thanks Diane. Getting very close. As you stated, this method does seem to be working..... sort of. When run it is populating the aapt.body with both the data from the cobbo box plus the data from the text box. However, regarding the combo box it only pulls the Case 0 strbody which = "subject 1" If I select "subject 2",3,4, or 5 the macro still only grabs "subject 1". Its like it is ignoring the orher selections.
Still researching. Probably right in from of my face. Let me know your thoughts when time permits. Thanks for the assistance as always and happy holidays!
George Z
Outlook 2013 64 bit
I am still coming up short on this. I sure you are sifting through numerous posts. Just wanted to see if you had any time to look into it a bit further as of yet.
George Z
Outlook 2013 64 bit
Just checking in, anyone have any additional feedback on this?
do you have Public lstNo As Long at the very top of the module?
George Z
Outlook 2013 64 bit
Sorry so log getting back to you. Had to back burner this for a minute. I did not have it at the top of the module. However I do now, and all is working as beautifully. Your the woman Diane. Thank you for your continued support and assistance.
I am having a few issues now getting multiple selections from a multi-select list box copied into an appointment however this is beginning a new topic so I will start a new thread on that.
Diane Poremsky Set Another Data File as Default When Using an Exchange Account New Slipstick.com Articles 0
Diane Poremsky Create Appointments Using Spreadsheet Data New Slipstick.com Articles 0
R can I transfer outlook data from old pc by using .ost file instead of the .pst Using Outlook 5
V Using custom field data in mail body + mailto hyperlink Outlook VBA and Custom Forms 7
S Using Send on Behalf is adding extra data in from line Using Outlook 1
R Disappearing data from outlook calendar after using icloud-ical Using Outlook 2
F Using Outlook 2007 as an IMAP Mail Station Without Saving Data Locally Using Outlook 2
M Scared to lose data using iCloud with Outlook 2007 Using Outlook 2
B Remove Outlook data file using another PC Using Outlook 1
P Using BCM2010 Business Projects as SharePoint 2007 Data Source BCM (Business Contact Manager) 3
M Mail Merge email using data from MS Access Using Outlook 1
J problem when importing contact data from one computer to another using .pst file Using Outlook 2
J trouble importing Office 2003 contact data (activities,etc.) using .pst file export & import to a se Using Outlook 1
J Word 2003 mailmerge using Windows Mail contacts as a data source Using Outlook 1
I Can I share BCM V2 Database on 2003 by using BCM Data Admin Tool BCM (Business Contact Manager) 2
C Cannot recover my Outlook 2007 Data File after using MS Backup - Kinda Critical as I need my business info! Using Outlook 11
