HELP!
b.reodis
I came to this site to ask and get some answers to my questions. I submitted one a couple weeks ago. Tonight upon logging in, the site said I had 25 messages, 1 like and 3 points (whatever they are). But when I went to my Inbox there was nothing there. Where did the conversation I started go to? Are there any answers?
My problem:
I can't receive email. I have Outlook 2007. I have at least 2 gmail accounts. I've been using it for years. I can go there and see my new mail, but whenever I use Outlook, and hit Send/ receive , it starts out at 80 or 85% and quickly finishes ... with no mail downloaded. I even tried deleting and re-installing outlook ... to no avail.
Even if I get this solved, the new year is almost upon us and I want to backup my .pst and start a new one called 2017.pst. I want it to show up in my window pane. I've figured out how to create 2017.pst but it's lost. I can't find it. I thought it was in Appdata, but no. How do I get my new .pst to show up?
Diane Poremsky has helped me before. I trust her.
it says you posted 26 messages - don't know why they aren't showing on the profile page, but they are here - https://forums.slipstick.com/search/783637/ - the earlier 2017 pst thread is here - PST trials | Outlook Forums by Slipstick.com
Are you sure no mail is downloaded? Could you be using a view that hides the messages? Can you find the missing messages using search?
Are you using IMAP or POP3 with gmail? If IMAP, you could try renaming the imap pst file and letting outlook make a new one - this (or a new profile) would have a better chance of fixing it, rather than uninstalling outlook.
You have 2007 so the pst file is either in %localappdata%\microsoft\outlook (paste that in the address bar of windows explorer) or in My Documents\Outlook Files - IMAP pst should always be in the localappdata path, but pst files used with POP3 or as stand-alone data files can be moved anywhere. (I forget if 2007 or 2010 was the first to move the pst files) - but it doesn't matter, you can create the new pst anywhere. If the pst was created in the default location, it will show up when you go to File, Open, Outlook Data File. If you still can't find it, search windows for *.pst
b.reodis
When it rains .... I went to that link and got (see snip #1). If you see, I'm logged in. Anyway, I had a letter to send so I opened Outlook and Lo and Behold, my mail arrived ... or most of it. But when I tried to open one I got this error saying "The server you are connected to is using a security certificate that cannot be verified. The target principal name is incorrect." Then it asks me if I want to continue using it. If I say "Yes", Outlook closes. If I say "No", Outlook closes and Office diagnostics comes up. It doesn't find anything but it's nice to know it's there. So, now I'm getting mail but I can't open any of it. The cert. is from hotmail.com and says it's good until sometime in 2019. I'm not a genius but something's wrong. Help? Oh, the letter I was going to send? I couldn't open my contacts so I can't send it.
sure sounds like something is goofy. is there a link to view the certificate? If so, what name is the cert assigned to?
M Winmail. dat - HELP Using Outlook 2
Diane Poremsky Help! My Contacts are being updated! New Slipstick.com Articles 0
B VBA Help Email that will save as draft and send as attachment Outlook VBA and Custom Forms 3
J Can Anyone Help?? Outlook VBA and Custom Forms 1
G Looking for help with our Organization Forms Library Outlook VBA and Custom Forms 1
A newb outlook macro help Outlook VBA and Custom Forms 1
X Help with custom form which is very similar to Tasks Outlook VBA and Custom Forms 6
P Outlook 2010: Missing tab - "Format/Picture Tools" HELP! Using Outlook 3
L Looking for help - want to try an alternative to Outlook? Outlook Wishlist 0
M Help! Can't set up IMAP for gmail Using Outlook 2
A Help with VBA please! Outlook VBA and Custom Forms 15
